Timing specs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by santana, Jun 17, 2003.
  1. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    What are the specs for a 350, HEI 4bbl? It's at 4-5 deg BTDC. Is this correct??
    Jerry. /forums/images/graemlins/k5.gif /forums/images/graemlins/ears.gif
  2. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    It does vary from year to year, and engine to engine application...
    Usualy they are set between 0deg and 10deg with the vacc line dissconnected.... /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    i think mine says 8* but one of the old timers at work taught me a trick... go to autozone or an equivalent, and buy an inexpensive vacuum gauge, hook it up to a vac hose that has vac at idle and disconnect advance from distributor... advance slowly until it peaks and then starts to drop, back it off, then do it again just a little below where it peaked at, tighten it down, take it for a ride..
  4. MousePowrd
    MousePowrd 1/2 ton status
    May 7, 2003
    215
    Saginaw, MI
    Your profile says 89K5. Did you convert it to carb? It all depends on the advance curve in the distibutor. 8 degrees is about normal, but if your distributor advances the timing too fast you will get detonation.
