Timing?
Discussion in 'The Garage' started by Chaddy, Apr 4, 2006.
  1. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    350tbi 90 blaze..... I replaced my plugs,wires, cap and rotor. Repaired a vaccume leak...I think its the only one. But anywhooo My idle is ruff after its all warmed up but drives perfect. If Im sitting at a light, the idle gets low like it wants to die but doesnt. When the idle stutters the oil pressure gets below 30 on the gauge??? Timing?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    are you sure you got all the leaks, you might want to make sure that your idle air valve is working proplery
  3. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    I don't know much about the 90's but is the choke openning up OK and the idle set right?
    Have you adjusted the idle mixture screws since the vacuum leak fix? It may be too rich now since you closed some of the extra air entering the system? Is the 90 with the computer controlled idle?
    The only computer in my 79 is when I drive it with my cell phone on my side.
  4. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    check for codes.... sounds suspiciously like an egr or iac on its way out..
  5. goldwing2000
    goldwing2000 Guest
    '90 is throttle body injection. No choke or mixture screws on TBI.
  6. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Bingo. My iac was bad. Now its perfect! Thanx
