Timing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Jul 7, 2000.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Ok, on my old truck all I had to do to adjust the timing was rotate the distributor, but on my 89 K5 I know it has a lot of electronics. Do I need to do anything else on it to adjust the timing?
    89 K5 Silverado
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    If your engine has an electronic spark control, there's a cable you should disconnect while adjusting the timing.
    Start enigne, disconnect wire, set timing as usual, reconnect wire. In my brother's TPI camaro, it's a brown wire on the pass side of the engine compartment near the A/C blower motor.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
