Timing
Discussion in 'The Garage' started by BlackDog714, Dec 7, 2002.
  1. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    Ok, I am having a complete and total loss of brain function last night and today.
    I just swapped in a 75 Surburban 454 (only 80,000 original miles!!! /forums/images/graemlins/shocked.gif) into my 1 ton. Well I thought it to be a great idea to swap out the intake and distributor... Long story short, I thought I put everything back the way it was supposed to be, however, when I crank the engine, it pops and backfires through the carb (newly rebuily Q-jet).
    What did I do wrong?????? /forums/images/graemlins/confused.gif
  2. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Sounds like you have the distributor 180 degrees out. Try taking the distibutor out and rotating it 180 degrees.
  3. BlackDog714
    Jun 8, 2002
    260
    Indiana
    OK, do I re-assign the spark plug wires on the rotor as well?
  4. or2play
    Feb 22, 2002
    657
    Yuma, Arizona
    nope, take the cap off. Pull the distriburtor strait out. Once it disengages from the oil pump shaft, turn it 180 degrees. Then put it back in, install the cap.
