  1. CenTxk5blazer
    CenTxk5blazer Registered Member
    Oct 19, 2002
    90
    Fort Worth, Texas
    I need to know the timing for a 91' /forums/images/graemlins/truck.gif with a 350 auto. Is it just top dead center?
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Probably around 8-10 before should be ballpark, there should be a decal under the hood, on the radiator support somewhere.
  3. CenTxk5blazer
    Oct 19, 2002
    90
    Fort Worth, Texas
    The writing on the plastic has rubbed off.
  4. BeaterK20
    BeaterK20 Guest
    every TBI motor i've ever seen "factory specs" on say to adjust it to "O" or TDC. i've heard that they run good at 8-12, but you sacrafice fuel economy.
  5. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    If its a spark advance controlled system, its usually zero.
    You will need to disconnect the wire from the ECM to time it. I assume that the setup you have.
