timings is off
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4x4 Cowboy, Feb 9, 2003.
  1. 4x4 Cowboy
    4x4 Cowboy 1/2 ton status
    Dec 7, 2002
    236
    california
    how do i set my timing. there ids no scale and no place for a timing light thingy.(dont ask how i passed smog its a secret) its a 350. if you need any more info let me know......... /forums/images/graemlins/frown.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    no place for timing light? that would mean you don't have a plug and wire on the number one cylinder. You don't have a timing scale next to your balancer?
  3. 4x4 Cowboy
    Dec 7, 2002
    236
    california
    nope i dont
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Not the best option, but if necessary, you could always time it by ear. /forums/images/graemlins/smirk.gif
  5. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    better to power time it than going by vacume
  6. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    What is power timing? My 454 says time it to 4*, is that an emissions thing or is that really where it should be?
    andy
  7. 4x4 Cowboy
    Dec 7, 2002
    236
    california
    take it to a mechanic for timing
    i am i gave up.
  8. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Are you sure you don't have a timing tab on the timing chain cover? I'm not sure what year it changed, but if you are looking at the front of the balancer some years the tab was at the 2o'clock and others at 12.Look down between the water pump and the block from directly above.
    If you really don't have a tab you can get a fancy chrome tab that bolts on to the timing cover for $3 at Idiot Zone(auto zone).
  9. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    I guess you realy looked..but just in case..did you look between the water pump and TC cover..sometimes the only way to see the scale is there...
    I am realy tired, I hope this makes sense
    If no scale..get an aftermarket adjustable one..that bolts to the timing cover bolts...
    find TDC on #1...screwdriver in plug hole, turn engine carefuly with socket..feel when piston gets to the top and starts down...rock it back and forth to get a feel...move it one way..mark the damper at one edge of the new scale ..rock it back until the screwdriver drops the same amount..mark the damper again..do this a few times to get a good average and the best repeated marks you can..
    .measure the distance between the two marks you made...1/2 way, make a solid scribe..turn the engine to align the edge to this mark..
    The engine is now at TDC
    If you can adjust the scale to align with this mark..do that, and grind or file a small slot
    If cannot adjust far enough...make another final mark on the damper at the 0deg mark on the scale
    Either way this will be you crank timing mark...Put the plug in, add timing light and set timing...
    If you are luckey..the OEM mark on the damper will be somewhere around you aftermarket scale
    Repeat the procedure above...after you get you two marks..Ignore the OEM mark for the moment...again, rotate the engine to the 1/2 way mark If you are very, very luckey..you will be able to adjust the timing scale so 0 lines up with the OEM crank slot... /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
