tips on dropping gas tank
Discussion in 'The Garage' started by Kartoon, Aug 24, 2005.
  1. Kartoon
    Kartoon 1/2 ton status
    Jun 14, 2005
    171
    Massachusetts
    im going to be putting in my ORD shackle flip on the rear of my suburban. i need to drop the tank so i can get to the inside of the frame. whats the best, easiest, safest way to do this? any help is appreciated
  2. dyeager535
    26,982
    191
  3. eric22
    eric22 1/2 ton status
    Oct 10, 2003
    139
    Lemoore CA
    my idiot friends just cut the straps... ooops ;)
  4. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Make sure its empty or at least close to it cause its heavy as heck! You have to drop it down a bit so you can get to all the hoses, and electrical connections. Make sure you take them *all* off and don't forget any....don't ask me how I know...lol ;)
  5. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    First dsconnect your filler hose.
    Now there are three ways you can do this.
    The first way should take you about 1 min to drop the tank. All you need is a BIG tree and a logging chain.
    The second way is two cut the straps.
    The third way is to get a few floor jacks. Raise the jacks up to the tank. Then undo the straps and lower the tank. Unhook lines as the tank drops. TIP: lower the tank VERY slow if you don't you will break stuff.
    Adam
  6. Kartoon
    Jun 14, 2005
    171
    Massachusetts
    thanks for the help. that recent post was very useful
  7. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,725
    11
    Washington State
    Just started this recently. I got the bumper off which was not needed. Niether is the hitch which was a pain to remove. Removing the heat shield takes some work to get it off the lip of the tank but it comes off with removing 6 bolts. This was not as heavy as I thought it was. I used a jack to support it.
    I have yet to lower the tank. I;m really concerned about breaking stuff. The connections are way inside the middle and it is hard to reach in see what to do. I;m not sure how many connections but at least 3. My concern is that some of the connections are steal lines and that I might bend them. All the fuel hose should be replaced with new as it looks really bad. I tought about removing the clamps in the fender well for the gas inlet to the tank.
  8. dyeager535
    26,982
    191
    Personally I take the fill lines for the tank loose from the fill end (instead of tank end) because you can get to them. Unless they have been off lately, they are a real pain to twist loose.
    I put a floor jack under the tank, remove the straps, and slowly let the tank down. Almost invariably whatever gas is in there shifts just enough to cock the tank, but all the lines (including the fill lines still attached to the tank) do a good job of holding it steady about where I need it. Then I just reposition the floor jack so the tank won't go lower, and disconnect everything at the sender, and finally drop it straight down.
    If you were really worried about the tank dropping, if you have a floor jack (must for working on any vehicle IMO) you could build up wood supports on either side, so even if it did slip off the jack, it wouldn't fall very far. There really isn't much room for the tank to fall though, as when it cocks on the floor jack, in my experience it hits the body with the high corner, and wedges against the frame at the other end.
  9. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    Is it really necessary to completely remove the tank to do this? I'm about ready to put a shackle flip on my Blazer but I was hoping to just lower the tank just enough to get my hand inside the frame rails, hopefully without disconnecting anything except the filler hose.
  10. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    This is what I did when I swapped tanks (mine was beat to hell from the previous owner :eek1: ) Tank straps were like $20 new Then cut all the old lines and replaced everything might as well while your're in there. :D
    I hate putting old worn out parts back on :D
  11. wazzabie
    Apr 17, 2001
    1,725
    11
    Washington State
    How far can the the tank be lowered from the top of the tank the the lower part of the frame near the tank?
  12. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    enough to bolt the flip on but why not replace those old crusty lines while you have it dropped? :wink1:
