Tips on engine swaps
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by talldogg, Jul 27, 2000.
  1. talldogg
    talldogg 1/2 ton status
    Jul 26, 2000
    754
    San Diego, CA
    Howdy! Does anyone have any tips/experience using a cherry-picker to do an engine swap on a lifted Blazer. I've used them before but that was on a Camaro (a LOT lower). My truck has 4" of lift plus 33's, I'm affraid the hoist won't lift enough. I'd like to avoid havinf to pull the front clip. Thanks!!!!!
  2. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    let the air out of the tire some if you need to !
    I understand the jeep thing I drive a BLAZER!!
    Ken
  3. Nike
    Nike Registered Member
    93
    Jefferson City, Missouri
    I doubt you will have any problems with the cherry picker, most of them have quite a lot of travel. You might want to get your steel tape measure out and do some measuring though, and don't forget you can let the air out of your tires, take the wheels off, and use other good old Yopsnkee ingenuity .
    Blue
  4. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    My blazer is lifted 8" with 35's, (it'll get a little shorter when i find my sawzall) and i got the the engine over the front, i let all the air out of the tires, and used i think two links on the chain so that when the hoist was up all the way it just barely made it over the core support. if i did it that high, you should be able to get yours in/out, btw i've done camaros too, your right alot shorter, but not quite as easy as the huge engine compartment of a Blazer.
    RaisedK5
    "Friends don't let friends drive Fords"
  5. Nike
    93
    I doubt you will have any problems with the cherry picker, most of them have quite a lot of travel. You might want to get your steel tape measure out and do some measuring though, and don't forget you can let the air out of your tires, take the wheels off, and use other good old Yankee ingenuity. Thanks Nike Thompson
    Blue
  6. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    You can also pick up a little extra distance by using a manifold plate instead of running chains to the front and rear of the heads. This allows you to use as little as one link on the main chain. Most manifold plates have several different holes to connect the cherry picker to, so you have a few different angles to work with on the removal or install.
  7. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Just did the engine on my 6" lifted '90 Suburban. Took off the 35s and installed some 235x85s. The trick is to figure the exact measurement to max out the hoist and have the engine clear the core support, while allowing the engine to be put on the ground, or an engine stand. Then do the same thing in reverse. Good luck!
    ken
  8. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    I just finished an engine swap on my Blazer with 4" lift and 33" tires as well. The cherry picker will work just fine, I aired down the tires a little bit and took off the hood. Removing the hood is a good idea since you won't have to worry about it in the way and you won't ding it up. It's easy to re-install if you pay close attention to where the hinges are before you take it off. Also, make sure you have the picker set up properly or it could tip if you get too much out in front of it. The last thing you need is to see it falling forward when you start to lower it in and the weight shifts more to the front. I got lucky because mine dropped right onto the motor mounts on the first try. Good luck and think things over before you start each step and you'll be fine. I was nervous since this was my first swap, but everything went well, I just took my time.
    Post pics when you're done and tell us how it went.
    L8r,
    .Riz.
