tips on removing crank gear?
Discussion in 'The Garage' started by roadnotca, Dec 22, 2005.
  1. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I'm replacing the timing chain set on SBC, I guess I had never done it myself and had the gear pulled while the crank was in the shop.:confused:
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I always use a 2 jaw puller, when needed.
  3. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    two prybars or a gear puller.
    thats what works for me.
    or ive seen guys split the with a grinding wheel and then whack them with a chisel and a bfh
    ryan
  4. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Yea, now I'm remembering, the puller with legs screwed on, not the flopping links kind. OK, thanks guys, I'm moving again.:D
  5. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I use a 3 jaw puller, remember too not to junk the threads on the crank. I use a spare bolt with a pilot drilled in the head for the puller to seat.
  6. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Thanks Mr Fiber.
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    not a bad idea. i just had to pull the one off of my old 2.4 crank for my Grand Am yesterday. my 3 jaw puller has a pointed end, or i can change it to a flat end, i used the flat end on the end of the balancer bolt. had a hell of a time getting it started. pointed end with a pilot hole would've been MUCH easier.
