Tips on removing inner-axle seals on 10 bolt front axles
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by IGOR, May 19, 2003.
  1. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    How does one go about removing the front inner axle seals on a 10 bolt axle?
    Anyone have any tips?
  2. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    After you get it all taken apart, just use a broomstick or some kind of rod and a hammer. Stick it in the axle housing and tap.
  3. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    Cool -
    Of course~ I didn't think of that - /forums/images/graemlins/blush.gif
    I was thinking of pulling it out - not pushin!
  4. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    That's how you remove them? Do you remove them the same way if all the gears were still in but the shafts were out?
  5. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    I took mine apart yesterday - and I doubt you could get them out without pulling the gears. - They are pressed in from the gear side - and the carrier bearings would block the seal from coming out.
  6. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Thanks for the info
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
