Tips on Timing after new intake mainfold
Discussion in 'The Garage' started by 76_Cheyenne, Jan 31, 2003.
  1. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    I got a new edlebrock intake manifold in the mail, and I have never set the timing on my 350 before. After I get the new manifold in, is it possible to try and line the rotor and distributor back up without having to set the timing? Or is there any hints on how to set my timing back once the new manifold is in. This is a new area to me. /forums/images/graemlins/truck.gif
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    What you'll want to do, is before complete disassembly, take the cap off of the distributor. Then, where the rotor points - mark a spot on the firewall with chalk or a pen. Then, when you put it back in after replacing the intake manifold, line up the rotor with the mark on your firewall. That should at least get you in the ball park. You can then fine tune from there - then bolt it down and you'll be good to go.
  3. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    What he said,Even if you could set it exactly where it was it still would need to adjust a little diff cause of new intake. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
