Tire and wheel question
Discussion in 'The Garage' started by MOLON LABE, Oct 20, 2005.
  1. MOLON LABE
    MOLON LABE Registered Member
    Apr 15, 2005
    28
    Arizona
    I have a 90 suburban 1/2 ton 4x4.
    I'm putting a BDS kit, 2.5 front springs and a 4" block in the rear to bring it up to level or a bit higher in the rear.
    I wanted 15x10 wheels and 33/12.50 BFGs but was told they wouldn't fit but that using 15/8 wheels would. However, I was told that by using 15/8 wheels it would cause faster wear on the tires and cause drivability issues.
    Any thoughts on this ?
  2. 1989blazer
    1989blazer Registered Member
    Jan 7, 2004
    35
    Bay Area, CA
    My blazer has about a 3" lift front and rear. I have 15x10 Mickey Thompsons with 33" BFGs. it rubs with tight turns, other wise ok. I haven't really done radical off-road, so can't speak to rubbing with full suspension compression
  3. MOLON LABE
    Apr 15, 2005
    28
    Arizona
    So should I go with 32" tires to be safe ?
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    That shop be smoking da crack....................Sort of.
    With that tire and wheel combo, it will force the tire to crown somewhat in the middle, so if you're running respectable road air pressures, the middle of the tire will wear faster than the rest of the tire. The only "drivability" issue this will cause is that since the tire will not have a contact patch across the width of the tire, it will be a little more susceptible to leaning than having the tire on a 10" wheel. As long as you are a decent driver and can realize and understand the changes stuff like this causes, these issues the shop has brought up will be very minor in the scheme of things.
    That's all from personal experience. I wouldn't worry too much about wear either since the BFG tires wear like iron. :D
  5. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I run 32's With no lift and 15x10's. Ihave had passenger front and driver rear off the ground and no rubbing, sure it was close though...
  6. dyeager535
    26,980
    33x10.5R15's fit most rigs wth stock wheels, no lift, and no rubbing.
  7. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Had that setup too, no rubbing like dyeager535 said. kinda looked funky though, IMO
  8. MOLON LABE
    Apr 15, 2005
    28
    Arizona
    So it sounds like this guy was FOS.
    So you're saying that with the lift described above I should have no problem using 15x10 wheels and 33 12/50 15s ??
  9. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    I prefer the 10" rims. you most likely wont have probs but every truck sits different
  10. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    If you do have a problem clearing those tires, just trim your fenders a bit... there is a guy with 2.5 lift springs on here that runs 37's..... :bow:
  11. MOLON LABE
    Apr 15, 2005
    28
    Arizona
    So if I understand correctly, with the lift I outlined in my post above, I should be able to run 33x12.50s BFGs on a 15x10" wheel with no issues ??
    Or am I reading this wrong ?
  12. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    What I'm saying and reading is that it will prob. be fine but no guarentee cause every rig's a little different. Go for it.
