Tire and wheel tech help
Discussion in 'The Garage' started by Grim-Reaper, Jun 30, 2003.
  1. Grim-Reaper
    7,385
    Atlanta
    Ok here is the deal. My burb has them up pizza pan hub caps and I HATE THEM. Tires still have lots of miles on them.The are On factory rims that I think are 6.5 wide.
    I found a set of rims I like but the rim is 8 inches wide. The tires are 235 85 16 is that 8 inch rim too wide for that tire? These tires are wearing great but I hate to screw up the handling or cause the tires a problem since they have been on the narrow rim. E rating tires are EXPENSIVE and I can't justify replacing them right now.
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Buy the rims you like. Just let them sit in a corner till you're ready too get new tires. /forums/images/graemlins/thumb.gif
  3. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Hey Grim--talked to my local tire shop (he's got over 30 years experience) and he said you could mount them up on the rim and they would wear even if you kept the air pressure low and consentient. The down fall of that ,of course, is you don't get to use the full weight carrying capacity of the "E" rated tires. /forums/images/graemlins/frown.gif Which you need on your burb for towing duties. He recommended not to use that narrower of tire on a 8" wide rim.
    Hope that helps.
    Eric
  4. CK5
    May 19, 1999
    21,627
    704
    CO
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Cool steve /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  6. Grim-Reaper
    7,385
    Atlanta
    Hope that helps.
    Eric
    Bummer. See that's my exact problem.
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Not only will lowering the air pressure effect load carryng.
    It will also knock your gas mileage down because of increased restance. If i rember right. Weren't you on some kind of a gas mileage quest?
    Keeping higher pressure in your tires helps gas mileage.
