Tire/axles size servey!!!
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Rasberry, Jun 27, 2001.
  1. Rasberry
    Rasberry 1/2 ton status
    Mar 30, 2001
    205
    Orlando, Fl
    Whats size tires do you have on what size axles 1/2, 3/4, 1 Ton? If you have 1/2 ton whats the biggest you'll go.
    I have 35" BFG mud terrian with 3.73 gears. I no longer use my Blazer as a daily driver so I'm going to upgrade to some bigger super swampers.
    I was thinking 36X14.50 or 38's. Will the 38's give me much trouble. I know lower gears will help with the bigger tires but gears will have to wait for now. I don't want to be replaceing u-joint and axles everytime I take the truck out.
    What do you guys think on this matter?
    Rasberry 71' K/5 Blazer
    <A target="_blank" HREF=http://www.geocities.com/71blazer>http://www.geocities.com/71blazer</A>
  2. blazin72
    blazin72 1/2 ton status
    Oct 24, 2000
    279
    Oklahoma
    I run 35-12.50-15 on my stock 373 gears and stock axles.
    I wouldnt go over 36's on stock axels looking for problems.
    But then again it depends on how much and how hard you wheel.
    Just my opinion.
    Blazin72
    Blazin 72
  3. 1_FN_HI_K5
    1_FN_HI_K5 Registered Member
    Dec 31, 2000
    22
    I am running 44x18.5x15 super swampers on my 72 blazer with a dana 44 reverse rotation 1/2 ton axle with 5-13 gears up front
    and a dana 60 rear.
    It all depends on what you like and how much MONEY you are willing to spend for all the up grades to run such a tire.
    1 FN HI K5
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    I run 31x10.5 on stock axels and that's the biggest I'll go, no wait i think i got 33x12. I think i need a gear upgrade now, some 3.73s. na, mabe i need axel upgrades and 35. that's the biggest I'll go. this just never ends, does it.
    ARQ.
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I have 36x12.5x15 Swamper Radials and 3/4 ton axles with 4.10 gears. I wheel it hard and broke my 1/2 ton stuff a lot when I ran 33s. I havent had a chance to abuse it that much with the new setup but it should hold up a lot better.</font color=blue>
  6. not4show
    not4show 1/2 ton status
    Apr 24, 2001
    280
    Alabama
    I run 35s on a Dana 60 front and a 14 bolt rear. You could get away with 35s on half ton running gear, maybe even 38s if your careful. That's just my thought on it.
  7. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Ask your self what kind of off road driver are you?
    Do you love to hammer down when trying to climb something or do you first try to crawl up that hill? It is my .02c that if you are running stock D44 front and stock 12bolt rear with 3.73s then 35" is your max. Now if you have 'beefed up' your stock axel housings with aftermarket axel shafts and stuffed in a nice posi or locker and do a gear swap to 4.11 or 4.56 then thoes 1/2ton axels could handel mabie 36" or 38" Swamper. 38" would be pushing it a bit but with good driving tecniques you could servive the trail just fine.
    I am running 33" on D44front w/Warn axels & DanaPower-Lock w/4.09 R&P. The rear is a Dana60 w/MarkWilliams axels & DanaPower-Lock w/4.11 R&P. Someday I may step up to a 35"SSR Swamper but I realy like the torque I have to the 33s at the ground right now. Lots of grunting and lurching......[​IMG]
    <A target="_blank" HREF=http://www.geocities.com/baja/5099>http://www.geocities.com/baja/5099</A>
  8. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Wait just a minute buuuudy.
    What the he(double)l is this someday stuff. I thought you had the green light from the boss and were already to get the SSR's. I wanted to see your rig sitting on those by x-mas and now your telling me that I might not be able too. I think I need a beer....[​IMG]...............Oh.....that's right..........it's only 7:15. I guess I will stick with my coffee for now. [​IMG]
    See YA Bro,
    Keith
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
  9. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Ive got a Dana 44/12 bolt .Couldnt swing the molly shafts for the 44 but I did install an Auburn and 4.10s when it was rebuilt.In the rear I got Moser shafts a Detroit and 4.10s.I mostly play on the rocks and Im not a gas & bash type guy.I think the biggest I would go would be 36 or 37x12.5.
    <A target="_blank" HREF=http://community.webshots.com/user/beaterwhang>http://community.webshots.com/user/beaterwhang</A>
  10. Rasberry
    Mar 30, 2001
    205
    Orlando, Fl
    My Blazer is mostly used for slinging mud, theres not much for hills or rock climbing in the middle of Florida. I don't bash around to much. I just need to know if these axles can handle turning 38" all day.
    But I must say these 35" BFG M/T have been quite impressive in the mud.
  11. Burt4x4
    6,854
    LMFAO hehehehee, Yes I still have a green light! BUTT I didn't buy the first one yet and that 200 bucks just got sucked up from my damn steering box taking a crap on me[​IMG]!!!
    SO.....I still hope to have all 5 before X-mas...... Ya know I am thinking of sticking with 33"ers too...........Just gives a bit more power to the ground and less stress on the axels......
  12. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Burt4x4 - you should get a 5-speed into that Blazer of yours too... Those 4.10:1 gears must be heck on the freeway...
  13. Burt4x4
    6,854
    Ya I would like that 5speed you have! Someday mabie, for now the sm465 will have to do I am turnin 2800 at around 60-65 so thats as fast as I can go but my speedo is messed up too so don't really know how fast I am going....
  14. Rasberry
    Mar 30, 2001
    205
    Orlando, Fl
  15. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I am running 40" tires with a D60 front and a 14B rear with 4.56 gears.
    If you build it, the mud will fly!
    72 K5 blazer 1 ton with a 427 tall deck and TH350/NP205 and 12"of lift with 40"tires.
  16. Burt4x4
    6,854
    Hey cool 66.9 MPH at 2800rpm.
    Thats a nice calculator! It even has the charts to figure in the trannie and xfer case..Coool!! [​IMG]
  17. Steve_Chin
    Mar 6, 2001
    1,126
    Oops... Forgot to post my whimpy running gear:
    All half ton running gear (D44 front, GM Truck 12-bolt rear). 32x11.50-R15 Bridgestone mudders on 15" x 10" Eagle wheels. No lift (yet). I will probably be going to 33" or 35" tires when I get lift. I wish some tire company would make 34" tires because the 33" tires are really close to being just right for my needs and the 35" tires are a little on the big side. Oh, well...
  18. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I've got 1/2 ton running gear (D44 & 12Bolt) and 36x12.5 Supper Swampers (which I just got this week). I have a 4" lift and the tires rub. Even when driving on the street! The fenders will be cut before I take it out to have fun in it. I also have 3.73 gears and it is now a dog off the line (I could peel out 33's). Time for a axle swap w/ 4.10 or 4.56.
    '71 Blazer CST with alot of rust
  19. Rasberry
    Mar 30, 2001
    205
    Orlando, Fl
    Triaged, do you have pic of your new tires I could see. I'm riding on a 6 inch lift so I don't think they will rub. I think I'm going to go with the 36" swampers.
  20. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Hey Steve, did you actually measure the tire's loaded radius for your calculation? My 35's measure a true 33" and a bit...
    My 36" Swampers on the other hand measure over 35 1/4" and they only have 30% or so left on em...
    BTW I haven't had a speedo for 4 years now, I have figured my speed with the tach for so long i'm usually within a couple of MPH of where i should be when it counts.[​IMG]
    Rene
