Tire balancing without weights, who's done it?
Discussion in 'The Garage' started by 88K5Jimmy, Nov 26, 2003.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Tire balancing without weights, who\'s done it?
    My 36" Parnelli Jones are about to vibrate the fillings out of my teeth (if I had any)!! I got them balanced but that didn't really do anything. Has anybody ACTUALLY used mouse balls, golf balls, whatever to try to balance their tires? I'm getting pretty fed up with the vibes I get at highway speeds.
    Also, is there a formula for calculating how much weight you need or is the best way to see how far the tires are off, weigh whatever you are using, and then go from there?
    Ross
  2. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    Re: Tire balancing without weights, who\'s done it?
    i had a set 33s before and couldnt get the shakes out of them . so i had a tire store use a powder balance it worked for mine. the tire store folks know how much powder to use.
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Having worked in a tire shop I will say that the equal sand, mouse balls, bb's, and the like really don't do much except at highway speed (above 65mph) big rigs use that type of stuff and it works at speed. (watch one on a suface street and it'll be vibrating like crazy) I had a customer once with some balancing discs behind the wheels of his '97 3/4 ton Dodge ram with 37-1250-17 MTR's. These discs are more common on large motorhomes and F-550's than any normal civvy rig. It is a ring with a couple ounces of material inside. The disc is about 14" and has a plate inside with you bolt pattern. They aren't cheap and I don't know what they are called or who makes them. If you wanted you could call around to a local big rig type shop and ask.
    hope this helps.
  4. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i use equal tire balancer and it works great on my 37 SSR's
  5. purple76pearl
    purple76pearl 1/2 ton status
    Jan 13, 2003
    450
    missouri
    i use equel, i run micky thompsons 35/17.50/15 which are a huge wide tire, at first i ran 1 bag per tire, and still was pretty bad shape, now i run 2 and half bags per tire and the only shake i get is at 95 and thats my drive shaft thats my 2 cents worth
  6. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    I think Shaggy used the mouse balls.
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I used the powder balance on my 38" radials, and my buddy in his 38" ssrs. I have heard they dont work to well, but we have yet to feel any vibes.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    They don't make 38" SSRs.
  9. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ]yep
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nevermind I lied. Must be a new size. /forums/images/graemlins/thumb.gif
  11. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    if they still made grand prix's,those were the poop. my 40's on 16.5in rim's never shook. only flat spots until they warmed up. and that was not bad. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  12. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i heard you can balance with machine up to 44" and no bigger
  13. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    I done used golf balls before. Added about 10mph so I could actually cruise down the road at 65 without felling like I was going to die.
  14. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Thanks for the replies. How do you know how much powder and how many golf balls to use?
    Ross
  15. balzackks84
    Aug 22, 2002
    1,344
    portland, oregon
    6 Golf balls per tire.
  16. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    How did you know to use six golf balls? Is that for your particular application or did you use a formula......
    Ross
  17. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    How do you know how much powder to use?
    The bags are made in certian amounts for differrent size tires.
    And they've had 38" SSRs out for a while now.
  18. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,603
    555
    Wasilla AK,
    there called centramatics we put them on some off the trucks that come in at my part time job
  19. earl87gta
    earl87gta 1/2 ton status
    Apr 6, 2003
    551
    Chuckey TN
    They sell those at the hummer dealers they are like 400 a set of four but work well they have an outer tube filled with BBand are made to use with the 37/12:50 tires you may be able to get a brand name and find them cheaper. Ive seen a few sets sell for around 150 on ebay.
  20. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Check 'em out here www.centramatic.com
