Tire Balancing
Discussion in 'The Garage' started by 2High4U, Dec 14, 2005.
  1. 2High4U
    2High4U 1/2 ton status
    Aug 20, 2005
    542
    Felton Pennsylvania
    A friend of mine has a tire changer, if i mount them myself is there any special way of doing this? How much does it cost to balance 33's
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    For home use there are the simple & cheap static balancers, just a stand you center the rim perfectly on, and add weights to any side that is dropping
    Stores usally charge $8-10/tire for balancing. Discount tire has a $35 or $40 lifetime, take it in, pay the fee, they balance, then you can take your rig back there anytime you want as often as your want for free balancing during the life of that tire.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    For a 33 you need about 8-10 oz of dynamic balancing and you never have to touch them again. I am putting 14oz of airsoft BBs in my 37s. Try 3 old golf balls you can buy xouts at your store of choice for about $5 a dozen.
    If you want to know how many air soft pellets you need check here.
    http://coloradok5.com/forums/showthread.php?t=145208&highlight=air-soft
    Ira
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
  5. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    I run 35's with no balance at all, and they feel just fine;) I have them up to 70mph on a regular basis and I have no vibrations at all. U might try just mounting them and drive on 'em 1st and see if U even need to balance 'em.
  6. sandawgk5
    Oct 28, 2003
    6,881
    Fixed it.
    Thanks for the heads up.
    Ira
  7. sweetk30
    Nov 1, 2004
    25,534
    530
    horseheads , ny 14845
    same exact thing for me also.
