Tire Carrier Hinge
Discussion in 'The Garage' started by cbbr, Sep 21, 2006.
  1. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I am working on a carrier built out of 3/16ths 2" square tube.
    My thought is to sleave a 1 inch grade 8 bolt with DOM. Weld a piece of the DOM into the main bumper and the carrier. Since it won't be opened that often, a lttle grease on the bolt should do.
    Anyone done this?
    Anyone know the shear strength of a 1 inch grde 8?
    Would a grade 5 be better (less brittle)?
    Any drawbacks?
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    If I am envisioning your setup correctly, it will wobble like a sumb*tch. You'd be better of to get a trailer spindle setup out and use that. You can get them cheap from Northern Tool.
  3. cbbr
    Jul 17, 2004
    14,681
    I am looking at DOM with an ID of 1.06 and a 1" grade 8. The carrier will also be bolted down on the other side.
    I have read a lot about the spindle setups and the rockstomper hinges, but people have had problems with them breaking.
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    That .060" slop is too much. As previously predicted I also predict that it will wobble. Bolting it on the other side will only help that side.
    If you're determined to go in this direction I highly suggest that you buy a pair of flanged bronze bushings with a 1" ID and size the steel tube for them to be a light press fit. Can get them from your local bearing house.
    Nominal Shear strength in steel is roughly 57% of the tensile strength.
  5. cbbr
    Jul 17, 2004
    14,681
    My other choice is 1.01. If slop is the only downside, that may help some.
  6. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    IIRC, they use a 1.5" dia. spindle. Go with the 1.75" dia spindle and larger OD dia. bearings. That will help a lot with the wobble and should prevent breakage.
