tire deflators
Discussion in 'The Garage' started by aknight_sa, Sep 29, 2006.
  1. aknight_sa
    aknight_sa 1/2 ton status
    Oct 14, 2005
    305
    Saudi Arabia
    hi guys,
    anyone used any of those small automatic tire deflators?? which is best recomended?
    thanks
  2. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    A buddy of mine has the ones you set at a specific pressure and they stop there, very cool. Some day I will get a couple of sets for my truck and 5th wheel for when we go to the beach.
  3. aknight_sa
    Oct 14, 2005
    305
    Saudi Arabia
    do you know what type he has??
  4. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Staun maybe.
  5. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    I have a set of Staun's. I really like them. They have three different pressure ranges, I have the 6-30psi ones. I think I paid $57 for them. Once I get my bead locks on, I may get a 1-10psi set.
    I usually just screw them on when I get to the point of knowing I want to air the tires down, it takes a few minutes for them to deflate. But they shut off when the air down pressure is reached.
    It did take some time adjusting them the first time, I used a spare tire, and kept adjusting reach one until I had them set. Once this was done I have not had to readjust them.
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Go to McMaster-Carr and enter in this p/n: 4772K4
    $6.43 each, they come in 5 psi increments - need to specify which when ordering. Mine can be massaged to change the pressure, but I haven't bothered.
    Then enter this p/n: 6146A23
    $2.10 each
    Screw them together and you have a pre-set deflator for less than $10.
  7. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
  8. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I have the Staun deflaters. Just screw them on and go sort your gear out, talk to your mates or what ever and they'll be done when your ready. You preset them to whatever pressure you want.
    I actually bought and still have a set of Staun Rapid Airdown valve which are cool but I couldn't use them with my Staun beadlockers. They're fast but not preset so you'd have to keep checking the pressure.
  9. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    True, they aren't very faster but they make up for it in farting sound!
    Like SouthernSpeed I set it up and go do other stuff. Usually what I do, as so far I only have one, is pull out the self-coiling hose that I use to balance the rear tire pressures (Detroit) and set it to air down the rear. While that's going on I drop the fronts down close individually, and bring the self-coiler up to the front when the rear is done.
  10. spoolnaround
    Apr 8, 2002
    1,419
    Kingsburg Ca
    My buddie's Heep was aired down before I finished airing down. He runs 35's and I run 38's. I have to ask him what kind he has.
  11. aknight_sa
    Oct 14, 2005
    305
    Saudi Arabia
    it seems that Staun is the most popular deflator...
