tire fit
Discussion in 'The Garage' started by bighutch, Jul 10, 2006.
  1. bighutch
    bighutch Registered Member
    May 16, 2004
    12
    I have a 84 Jimmy that I put a 4 inch tough country lift on and 33x12.50 tires rub the rear of fender opening if I am turning out of my driveway. I thaught there would be no trimming needed.
  2. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    Every truck is different, although that is weird that 33's rub. Time for some :hack:
  3. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    should be plenty of room. you sure its your tire and not your axle?
  4. kwissman
    kwissman 1/2 ton status
    Jan 14, 2006
    118
    Austin, TX
    When I got my Blazer it had no lift and 33 - 12.50s on the stock rims and it did not rub. How much backspacing do your rims have. The less the backspacing the larger the radius that the tire will make when turning. I currently have 38s on a 4" lift with no rubbing but a lot of cutting. Time to cut.
  5. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    What is your rim back spacing?
    I've run 33x12.5 on stock rims (3.75in BS) and only 2in of lift with no contact.
  6. greenbeater
    greenbeater Registered Member
    May 24, 2006
    19
    michigan
    sounds like a bs issue
  7. bighutch
    May 16, 2004
    12
    I have 15x10 us wheels with 4 inches of back spacing. The tires don't rub all of the time just when I am turning sharp backing out of my driveway where the dip is where the drive and road meet.
