Tire for Sand Drag Racing.. Opinions?
Discussion in 'The Garage' started by 83ZZ502_Jimmy, Apr 9, 2002.
  1. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I know what you are thinking, "dont you do this". Yes I do. I have used BFG AT's and MT's with good results. I am using 35" AT's on the Jimmy right now. But I have upgraded from the ZZ4 to a ZZ502. I spin the tries all the way down the 300'.
    Some people use boggers and some use an AT type tire. I should run paddles or scoops, but in my class I need a DOT type tire. (I can cut them)
    Anyone have any ideas. I need something in the 35-36" range. I have a 4" lift, but it's not like I'm rock crawling. I just dont want to throw money at it forever.
    Thanks in advance,
    John
  2. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    cut the boggers into a paddle style......
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    seen a lot of people use boggers and BFG MTs down in baja, there's sand drag races every friday night :-)
    ARQ.
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    My money would go for either Baja T/A's or Yokohama Geolander MT's. Both do killer in the dunes, so I'd assume they'd do well in the sand drags.
  5. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    For sure, go with the boggers. You can get them really in a wide 35 inch tire, I think like 16 inches. Cut them if you want. I doubt you'll find a more "paddle like" tire that is DOT legal.
  6. aksidentproan
    aksidentproan 1/2 ton status
    Dec 8, 2001
    477
    Maryland
    I heard super swampers new sts is supposed to be killer in the sand.
    Evan
  7. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Take a set of Boggers and cut out every other piece of tread. They will work great. Just dont drive them on the street because it will kill the tires.
  8. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    what sand drags you running? Charles City? Bodatious? Saluda?
    just curious cuz i wanna come watch if you run your k5
    Later
  9. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Its Newtown dragway. They used to be out at Saluda. They are in King and Queen county now.
    I run every event they have. Come up and say hi. You can see my picture here www.newtowndragway.com
    John
  10. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Go with the new TrXus STS tires. I have a set of their 38's and they work great on many terrain types. I have not tested them in sand.
  11. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    shoot you going this weekend? sat. i have to go to new kent to pick up my 14 bolt that just got gears and a locker put in it...i might be able to make my way up there...
    Later
  12. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    hey man im pretty sure ill be there tom. ill bring the digi camera with me so i can snap some videos and shots of you guys running.
    Later
  13. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Ok this is strange because on my search every other post was saying stay away from the boggers because they dig you into the sand. I have raced atv's on the sand for years and understand running paddles, but what about a HEAVY K5. Should I still go with the boggers for sand or should I look into more of a less aggressive tread pattern?
  14. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I don't know how well they work with a lot of horsepower but Mickey Thompson baja belteds (33-36'' range) seem to be the best sand tire that I have ever used. Also Dick Cepek fun country's work very well and don't seem to dig hard. If you are only running sand, it is a close call between the two, but if you wheel in anything else, I would say go with the baja belteds.
