!!! tire / gear size !!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lifethroughdeath, Mar 16, 2003.
  1. lifethroughdeath
    lifethroughdeath 1/2 ton status
    Jan 26, 2003
    300
    New Bedford, MA
    (posted in G1 forum accidentally) ive had my '90 K5 for about 2 months now and its all stock, (FOR NOW!) way too much i want to do to her in the future. with no lift on the tire size chart it says you can use a 31" tire without any problems, and a 32" with minor trimming, would i have any drivetrain related problems (overheating my auto 700r4) if switching to either of these without changing my stock diff gears, these are only going to be temporary until i can afford a lift and bigger tires and EVERYTHING else on my LONG list of mods, but for now my tires are BALD /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/k5.gif
  2. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    Well you didn't give aus a whole lot of information to go by, but I think you should be able to go to a 31-33 without re-gearing. If you have big plans for the truck, you don't want to regear before you ned to. It costs approx $500 per axle for a shop to regear.
    What is your gear ratio now? 3.08? 3.73?
  3. lifethroughdeath
    Jan 26, 2003
    300
    New Bedford, MA
    i have no idea what gears i have, i just wanted to make sure that the 32" tires would give me no problems with anything on my truck, how bad will a 32" tire rub on a stock height 90 K5, only at full turn /forums/images/graemlins/1zhelp.gif
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I used to have 32's on 10" rims and they never rubbed.
  5. dyeager535
    26,980
    Had 32x11.5R15s on stock 1983 K5, 15x8 wheels, and they never rubbed.
  6. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    I got 32x11.50's on 10" rims. The first tires I had never rubbed. My BFG mud terrains used to rub only on compression while turning. After a little problem I had with an unexpected 4 foot drop they would rub all the time when turning but only a little.
    It really depends on if your springs are saggy or not. Either way if you do rub it won't be by much and you should be ok.
    I now have a lift so no more rubbing for me until I get new tires.
  7. Madbomber88
    Madbomber88 1/2 ton status
    Feb 7, 2001
    185
    Mass
    I have 32x11.5 on my otherwise stock 90 (stock aluminum rims) as well and it doesn't even come close to rubbing. I have 3.55 gears and they work great, cruises 70 on the highway barely reaching 2200 RPM.
