tire patch
Discussion in 'The Garage' started by 4xrick, Feb 4, 2004.
  1. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    so I have an almost new set of 53x12.50/a5 wild country txls and i was rotating them one got set of to the side and droped on a nail and it went right through the side wall, I went to les schwab and they said they cannot patch it because of liability issues, I dont use the truck for anything other than wheelin does anybody know if there is anyway of patching/fixing this? I appreaciate any input thanks
    Rick /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    keep trying different shops, someone will probably do it for ya, especially if you knew them. Can also tube it if you had too....
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The liability issue (as I currently work for a large tire co.) isn't with you. It is with the other sue happy a-holes out there. You can find a small private used tire shop and most of them will do it as they only have overnight liability. Just be aware that the tire is not perfect in the eyes of an insurance investigator at an accident.
  4. 4xrick
    Sep 14, 2003
    1,102
    kirkland Wa
    i guess i will try to find a small shop around that will do it I rarely ever drive the thing and when i do it is only to go out wheelin so not much of a accident (on-road) happening there. /forums/images/graemlins/waytogo.gif
  5. 4xrick
    Sep 14, 2003
    1,102
    kirkland Wa
    ok so i cant type i see a made a little mistake in the tire size not that it matters 35x12.50/15 wild country txl /forums/images/graemlins/blush.gif
  6. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif
  7. 4xrick
    Sep 14, 2003
    1,102
    kirkland Wa
    thanks andrew thats a big help /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  8. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    i was rotating them one got set of to the side and droped on a nail and it went right through the side wall,quote]
    Side wall punctures are not repairable. As the tire flexs the patch will lose its seal. This can be a very dangerous situation, when you hit a bump and the tire flexs and the side wall zippers open. This is especialy dagerous on a lifted vechicle. If the tire were to suddenly lose all its air pressure, the axle will drop (on a 35 about 9 inchs) this will cause the weight to shift and can easily result in a roll over. Do not fix the tire replace it, Is your life or your familys life or the family in the lane next to you worth the price of a new tire?
  9. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    They will pro rate the replacement bro. /forums/images/graemlins/thumb.gif
