Tire plugs to cut or not to cut
Discussion in 'The Garage' started by garlicbreath, Jun 4, 2006.
Tire plugs cut em or eat em
  1. Cut em off, they aren't paying for the ride
    24 vote(s)
    57.1%
  2. Leave em be, the assfault with have it's way with em
    11 vote(s)
    26.2%
  3. Park overnight and let the beavers chew on them
    7 vote(s)
    16.7%
  1. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Do you cut off your tire plugs or let the road chew em off?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I cut the cheap rubber ones, but usualy leave the cloth impregnated one alone.
    No real reason why either
  3. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    I have allways cut them off. you dont want the ends grabbing the road movin around.
  4. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Too much work for me :D
  5. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    what are tire plugs?
  6. garlicbreath
    May 17, 2003
    1,136
    Denver
    Little foam things you put in between the lugs to make them ride quieter.
    :eek1:
    They sell them at auto stores, wally world, etc.
    Fixes holes in tires with a really sticky hard to handle worm you cover in goop then shove in the hole.
  7. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    too lazy to cut them, one more tool I'd have to keep in my emergency tire repair kit (somehow I go through a dozen plugs a month, in my onroad ride).
  8. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    A tire plug is an impregnated piece of rubber material.. about 1/8 inch in diameter...
    when you have a flat tire..such as a nail puncture.. the hole is roughed up with a special tire awl..like a rasp.. then the tire plug is soaked with a special glue that vulcanizes chemically to rubber (the good glues do.. the cheapies dont)... the plugs are about 4-6 iunches long for truck type tires... they are inserted through a big awl..like a huge sewing needle.. then inserted in the hole... pushed in then slightly pulled back out... cut off the ends.. glue sets.. refill the tire.. off you go.. good trail fix and necessary in your tool box.. I use them primarily on my tractor tires... I would use one for an emergency fix on a road tire but then i would replace the tire or have it patched from the inside
    I cut my ends..
  9. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    Always cut my ends, afraid of the road grabbing them and leaving my plug behind.
    ~Brian
  10. goldwing2000
    goldwing2000 Guest
    Ditto.
  11. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    If you used better plugs, you wouldn't worry about them pulling off, but you need to dismount your tire to use the good ones... =(
  12. goldwing2000
    goldwing2000 Guest
    If I'm going as far as pulling the tire off the wheel, then I'm going to patch it, not plug it.
  13. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I always cut them just to be safe. I never use the cheap walmart ones for anything but a temp fix. The best ones are made by Safety Seal.
  14. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I had to let the beavers chew on them since there was no nekkid option.
    I've never cut them and I've never had one pull out either.
  15. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    I leave em on. the directions say to cut the ends so you prolly should but Ive plugged many tires without cutting the ends and never had a problem. except for the one that had a 2 in cut in it. I put 15 plugs in and it held air till I got home then over night it all leaked out.
  16. garlicbreath
    May 17, 2003
    1,136
    Denver
    Ha, that reminds me of the time I used 20 plugs in the sidewall of my BFG MT to get me off quanella pass. All hail a spare, with air!
  17. eclmech
    eclmech Registered Member
    Apr 9, 2006
    24
    Ontario, Canada
    I always cut them. Had several pull out at work (I'm a maintenance supervisor for a construction company). Soft ground and rocks with tire spin gets them every time.
    Keith
  18. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
    Or being pulled out!
  19. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    I cut them off, I have seen them slowly pull themselves out otherwise.
