Tire pressure for 38 Swampers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Pure Insanity, Nov 22, 2001.
  1. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    What pressure do ya'll recommend for 16X38X15 TSL. They are not radials. I currently have 17-20 LBS in them. I used to run my 40 Hawgs at 22-25. I have never had Swampers before, and I am just not real sure of what I should run. They feel a bit spongy while driving, and seem to have some side sway.
    They are on a Blazer, w/ a 12 wide wheel.
    If ya can't stop.......Smile as you go under! [​IMG]
    PIC of mine from flblazers site<a target="_blank" href=http://www.flblazer.alloffroad.com/photo3.html>
    GO</a>
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    Run some chalk across the tread face and drive the truck for a short distance. Increase the pressure until the outer edges of the chalk don't scrub off and then lower it just a bit so the entire tread contacts the pavement. 17-20 sounds low to me...I think 24-26 would be a good ballpark and keep the sidewall flex in check. Heat kills tires fast and low pressure causes high heat...
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  3. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Thanx Rene. I'll up to 25 and do a check that way. I'll pirate my daughters sidewalk chalk. [​IMG]
    GO</a>
  4. elkboy
    elkboy 1/2 ton status
    Aug 18, 2000
    293
    Hillsboro Oregon
    I run my 39.5X15 X 16.5 at 30 on the road, any less and it wanders on the groovy pavement. I run it down to about 15 off-road for flex.
    <font color=red> Elkboy </font color=red> 82 K5 fuel injected H.O.305, TH350/205, 14bolt/10bolt and 39.5 TSL's.
  5. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    I am hopin it helps my mileage too. I driven about 50 miles and have burned a half tank! [​IMG]
    GO</a>
  6. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    I run 16psi in my 12.50"s, so you will need even less. Probably 13 or so. Running more won't help your mileage enough to offset the poor ride or center wear.
  7. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Hey Chris! I was beginning to wonder if you were still around. I was gonna send you a P/M by the end of the weekend, if I hadnt seen you.
    I am at like 17 now and I get alot of side sway and the tires just feel mushy.
    Ride quality is not a major concern. My thing is tire wear, and how they feel on the road. Kinda spooky to feel the back end sway around when your in a corner. [​IMG]
    GO</a>
