Tire Pressure Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1991K5, Jan 30, 2001.
  1. 1991K5
    1991K5 Registered Member
    Jan 30, 2001
    6
    I have a '91 K5, with 31"x10.5"x15 General Grabber ST's on it, and have no clue as to what the tire pressure should be on them, since the factory sticker is missing, and I cant seem to get any information from General about this matter. Thanks in advance for any help!
  2. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    The tire pressure should be molded into the sidewall of the tire itself.I've never seen one that wasn't.
    Chuck
    81 Blazer
    <font color=blue>does anyone have another F#@d that I can park on?</font color=blue>[​IMG]
    <font color=red><A target="_blank" HREF=http://www.chucks81k5.coloradok5.com>http://www.chucks81k5.coloradok5.com</A></font color=red>
  3. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I think that would be the maximum load at the maximum pressure, not your everyday driving pressure. The ride would be too stiff if you used that, and you'd probably wear the tires from the center sooner.
    The ideal pressure is the one that makes the tire have an even contact with the surface. That can be obtained by getting your tires wet and then rolling them on dry pavement. If they are overinflated, the edges of the tire won't be printed as good as the center. Reduce pressure until the print is even.
    <font color=blue>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A>
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    32 psi should be pretty good.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  5. CBLAZER81
    Mar 3, 2000
    281
    Milliken,COLORADO
    That's an excellent way to check for the right pressure/per vehicle.As for myself,the swamper SXs ride a little smoother with more air.
    Chuck
    81 Blazer
