Tire Pressure?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sammy, Jun 29, 2001.
  1. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    Or what pressure do you guys off-road. I run 35"X14,5" and weigh about 5500lbs. Auto deflaters stop at 8psi the lowest. So I would like to know if you (or I should) go below that.
    "1988 K5 Grand GT Blazer Silverado in the Netherlands."
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    no that sounds right. 8psi is the bare minium I would run. 10psi is my normal
    '83 GMC Jimmy 4x4 ZZ4 Crate Motor
    '83 Chevy P/U 4x4 Sand Drag Racer, 578 RWHP
    '94 Impala SS
    '01 Chevy 2500HD w/8.1L & Allison Auto
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    What brand name are those auto deflators? And do you think they are a worthwhile investment?
    Thanks.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.alloffroad.com>http://www.blazzinor.alloffroad.com</A>
  4. Sammy
    Dec 8, 2000
    250
    <A target="_blank" HREF=http://www.oasis-off-road.com>http://www.oasis-off-road.com</A>
    I think they are. I find deflating a real waste of time. I only do it becouse I have to but I don't like the job.
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Ive got 35 12.5s and I them run between 10 and 15lbs.I dont go any lower cuz when I drag a rock hard the bead moves enough to let out some air but not enough to pop it off the bead.I always thought if I went any lower than that I might have problems.
    <A target="_blank" HREF=http://community.webshots.com/user/beaterwhang>http://community.webshots.com/user/beaterwhang</A>
  6. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Frank, I just pull the valve out of the stem and listen to the thing deflate. After a couple of times you can 'hear' when you're close to the desired pressure. My bias ply Swampers I air down to 7 or 8 psi...but they are still fairly stiff. I may have to run em a couple of times with no valve stems at all to get the sidewalls a little more flexy.
    Rene
  7. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Ive got low $ deflators but there not auto.They cost $5.I use clip on tire inflators.Clip them on the stem and go.Ive got 4. Takes about 5 min to go from 30 to 10 on all 4 tires.Takes about 45 seconds per tire to fill from 10 to 30 with my C02.
  8. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    You can use the ends off the cans of fix-a-flat after the can is used up. That is what I use and there free.
    Ray
  9. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Thats a good idea too.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If I air down, I don't go lower than 20 PSI.....
    But I do mud at high speed.
    Tim
