Tire Question: 32s on stock suspension?
Discussion in 'The Garage' started by BJarvis354, Jun 19, 2002.
  1. BJarvis354
    BJarvis354 Registered Member
    Jun 17, 2002
    58
    New York City
    Hello CK5ers,
    I bought my first K5 (an '89) a couple of days ago after years of owning pavement cars. The only really terrible thing about it is the tires...They are 31x10.50x15 Bridgestone dueler H/Ts, which I had hoped would last awhile until I could afford what I want to replace them, alas they are REALLY bad on the wear front.
    My question is this: Can I run 32x11.50x15s on it without lifting it? I saw the tire fitment guide and it says "minor fender trimming" how much are we talking about here? I ran 32s on my old Jeep CJ-7 on a stock lift and had a minor rub problem, but I could have fixed that with new wheels I think, but I just adjusted my driving style.
    And before anyone suggests lifting it, I am in NYC and my buddy lifted his for 33s and regretted it. Ride was really bad, too many potholes and you can't get into many garages... :(
    Anyone have any suggestions on the tire itself? Costco has the Bridgestone Dueler A/T and BFG A/Ts, I want BFGs but they are about a hundred dollars more...
    Thanks for the help in advance...
    Brady
  2. creampuff90k5
    creampuff90k5 1/2 ton status
    Feb 15, 2002
    142
    New Jersey
    32's will fit with no problem whatsoever. In fact, you could probably even squeeze 33's under there with little or no mods (might have to hammer the fender trim a little at the corner of the wheelwells), assuming you don't wheel the truck too hard. FYI, people usually run into rubbing hassles when they switch from 8" to 10" wide rims, so stick with the 8" rims with stock suspension & larger tires.
  3. Chevit
    Chevit 1/2 ton status
    Dec 10, 2001
    1,492
    dnaltroP, nogerO
    I run 32's on mine with no problem...
    /forums/images/icons/cool.gif /forums/images/icons/cool.gif
  4. blazerboy72
    blazerboy72 1/2 ton status
    Mar 29, 2002
    260
    hiram ga
    my dad has had 3 or 4 sets of 32's on his and it has never rubbed <font color="blue"> </font color>
  5. Grim-Reaper
    7,385
    Atlanta
    Depends on the brand. I was able to run 32's on our stock 79 with just a little hammer time on the bottom lip of the fenders. Not even noticable where I tapped it back.
    I have a set of 32 inc BFG MT's for sale. 3 have 50%+ tread and one has 40%. They are on Chevy rally's. I would sell the tires for $100 for all four. $200 if you want the rims. If I sell the tires loose understand your probably looking at $50 for mounting and ballancing. Basicly it would be worth it just to get them on the rims. They may need ballancing. Really trying to avoid shipping these. I live in the Atlanta area.
  6. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    the dueler's are not good off road i think those are the ones my dad jus bought and couldn't believe it, they're pathetic, if you got the money bfg all the way, im poor otherwise i would have some mt's /forums/images/icons/smile.gif good luck
    Brett
  7. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    I had 12.50/33's on my K/5 when I first bought it(no lift).My neighbor has 11.50/32's BFG M/T's on his stock sagging springs.
  8. beefybluk5
    beefybluk5 Registered Member
    Jun 18, 2002
    6
    Washington
    I put 33X11.5 on mine. Just make sure you have newer shocks and no running boards on there and it does just fine. But lifting it is just so much fun anyways. Screw the 32's. just put a 3 inch body lift on it and get yourself some 35x12.5 tires. then itll be a real truck.
    just my 2 /forums/images/icons/cool.gif cents
  9. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i wouldnt personnally get bfg's anymore.my at's only lasted about 15 to 20 thou miles.so about a year and a half altogether.i have the wallmart brand super pro that im pretty sure is made by kelly tire and have had them for about 2 years with same milage and they still have half of the tred left.just telling you my personal thought of the bfg's and my experience.the tires were only 485 dollars mounted ballenced and lifetime warrantee.just something to think about.mine are 35s and i think the 33's would have been 460 alltogether.
