tire question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jasocbr, Oct 28, 2001.
  1. jasocbr
    jasocbr Newbie
    Oct 28, 2001
    Springfield, MO
    I have a 86 K5 and want to put 33's on it. To do this, will it need any kind of lift or will they clear at stock height?
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Oh, you will be able to ride down the street with them but if you turn a sharp radius they will rub as well as if you get one wheel stuffed up in fender well of either side of the truck.
    You'd be best at installing a lift of some sort. 2" for mostly street and light mud or a 4" for some simi moderate trail riding.
    Surgeon General's Warning:
    Viagra and steroids may be harmful to your spouse![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I ran 32's with no lift. It didn't rub in turns or offroad as far as I remember. 33's will fit with no lift. I would have run 33's but I have a set of running boards that they would not have cleared. It is possible that they will rub, but not sure. Now I have 2.5 inches of lift, and after my 32's wear out I am getting 33's. The 32's look a little small on 2.5" sometimes to me. 33's would look great.
    My Chevy isn't broken, its just out of gas.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have 33 and no lift they key to no rubbing is the offset of the rim i have a positive offset and do not rub at ALL i scorred 704 on a 23 degree rti ramp and still did not rub i also wheel fairly hard no rock crawling but still get fairly flexy take a look at the pics and videos in the links in my sig[​IMG]
    wheeling videoshttp://community.webshots.com/user/ssmith6333
  5. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    I got a 4 " lift and run 35's and I rub when off road in deep gullys or hard uphills. A buddy of mine has 35 MTR's and he claims never to rub and we go to the same places but all he has is a one inch ( hockey puck) lift. Sounds weird to me. But you should be okay unless you hit the trails hard.
    Brian
    83 K-5 4" on 35's
  6. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    I ran 33's and running boards on stock wheels with just an add a leaf in the front, no problem.
    Karl
    Temporarily Unemployed Underwear Model
    87 3/4 ton
  7. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Just brought a 78 with stock ralley rims and 33" tires...no rubbing but I am sure they would off road.The K/5 has HD frt. springs(3 leafs).
  8. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Lift it. It looks cool and helps with clearences.
    Shawnboy.
    If you are having too much fun it's probably illegal.
