Tire & rim size question
Discussion in 'The Garage' started by hidesertwheelin, Sep 18, 2005.
  1. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    I have a set for 36x12.50R16 SSR's. I can get for free a set of factory Chevy rims 16x6.5 8 lug. Do you guy's think this is safe to run? Thre tire says 8.5-11. wide rim, but these are free and free is good. What do you guy's think?
  2. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    go with their testing
    if it says 8.5 to 11 inch rim then I would say get an 8.5-11 inch rim. Free is good, usable is better.
  3. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    You can run them, it may cause the tire to crown and wear the centers out over time though.
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Most of that could probably be avoided by running a lower PSI all the time. Less air will help the contact patch ride flater on the ground instead of crowning with the normal amount of air.
    That being said, I don't know if I'd run them or not. Especially when white wagon wheels can be had for cheap enough.
