Tire/Rim Width
Discussion in 'The Garage' started by 79Stomper, Aug 9, 2004.
  1. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I have a set of 15x12 rims for my 3/4 ton conversion. I was wondering if I could fit a 12.5" wide tire on the 12" wide rim. Most places I see the manufacturer recommends putting them on a 10" wide rim but I have the 12" rims available and like the style.
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    It can be done but the tires may be hard to seat on the rims. Also, the end result will have ballooned sidewalls so the combo may look a little odd. I have 12" wide rims on 35" BFG's on my crew cab. They're ok for now but next time I may step up to a 14.50", wide 36" tire so it will look more "natural".
    Something I noticed when doing mine, the tread shape will effect the overall look a lot. For instance, the BFG All Terrain has a very square cut shoulder on the tread making the "balloon effect" much more noticeable and looked awkward. I found that the BFG Mud Terrain K/M has some cleating that wraps over the shoulder onto the sidewall a little. The wrap around of the tread helped to make the combo more eye friendly.
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Go for it, it'll look good.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The only problem that you might have is that you will probably loose beads easier. If it is a DD that doesn't see trail then it will probably be ok but if you see trail and lower your PSI for traction be careful with those beads.
    Harley
  5. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    That is what I was thinking too. I drive it once a week to work to keep everything fresh but other than that it sees the trails mainly. I think I will continue on my Journey for a set of 38's or larger tire. Really want to go bigger anyways. The 35's just look so tiny with all of that lift.
    Thanks for your comments/suggestions /forums/images/graemlins/waytogo.gif
  6. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Go for it I really like how a 12"wide wheel looks on a 12.50 It seem to work good and your sidewallys will look straight(I like) EXCEPT for on a BFG all terrian, It the one tire that looks odd on a 12 wide
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ] /forums/images/graemlins/screwy.gif You only have 6" of lift( from your profile). I ran 33's with 6" and it looked great.
  8. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    You could run that combo, but it may look a little odd. I ran an 11.5 wide tire on a 10" rim and it looked ok, but lost beads. If i were you id step the tire width up an inch so you at least get some sidewall bulge, if its even an option at this point.
  9. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    I see yer looking for 38's....if you dont mind ground hawgs I found some on Tyres1 for 155 ea! /forums/images/graemlins/yikes.gif I bought some, and figured I'd let people in on the sale too! /forums/images/graemlins/thumb.gif
  10. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Well from the profile I have a 6" Suspension lift a 1" body and zero rates so a total of 8" lift. If you check out the pics in my profile you can also see I have been /forums/images/graemlins/hack.gif to some fenders to make the body armor do its job.
    Thanks for the link on the tires. I was going to order a set of 40's from Nebraska tire but called them and they had sold them all /forums/images/graemlins/angryfire.gif.
  11. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    How well do the ground hawgs wear on the street?? I am looking to get some 38's and that is smokin price verses the ssr's I was looking at.
  12. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Another member on here sapper is running a set of 40" ground hawgs and they have been on the road for a few years now and still have a good bit to go to the wear bars on them, thus being the reason I am looking for a set, plus my truck doesn't really see that much of the pavement anymore. /forums/images/graemlins/whistling.gif
