Tire rubbing on PITMAN ARM.
Discussion in 'The Garage' started by sta500666, Apr 4, 2007.
  1. sta500666
    sta500666 1/2 ton status
    Apr 16, 2004
    291
    Dubuque/Ames, Iowa
    I have had my blazer for about 6 years and have just been too lazy to deal with this problem, but it has gotton to the point where I need to replace the joint so I want to fix the problem completely... I have 33X12.5 Tires and everytime I take a right turn and crank the wheel too far the side of my drivers side tire rubs on the end of the pitman arm. It has finally rubbed all the rubber covering the joint off. I see other people running the same size tires and they don't seem to have this problem. I don't have a lift kit. Is there a way to make this so it doesn't happen, preferably an easy fix??? This summer I'm swaping both front and rear differentials for larger ones so that would be a great time for me to work on the pitman arm problem.
  2. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    different wheel backspacing could make a difference.
  3. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I had the exact same problem on my blazer but it went away after I got my new wheels. I am running 15x8 wheels with 3.5 in backspacing.
  4. sta500666
    Apr 16, 2004
    291
    Dubuque/Ames, Iowa
    is backspacing just where the distance from the middle of the wheel?? Can you buy a plat to do the same thing?
  5. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
    You can get wheel spacers but they are $$$$. They would be a waste if you are going to 8 lug in a few months.
  6. vortec
    Jul 22, 2004
    1,472
    fort worth, texas
    spacers are certainly available, but i'd say a wheel with different backspacing would be better. less stuff bolted together=less stuff to loosen. just my opinion. either solution will apply additional force (more leverage) to the wheel bearings and likely make them wear faster. something to consider when selecting how much extra spacing you want.
  7. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    you can get just a plate that goes between the wheel and the hub from summit racing
  8. sta500666
    Apr 16, 2004
    291
    Dubuque/Ames, Iowa
    for sure, im getting wheels thrown in for free with the diff's im getting... hopefully they have the right backspacing. Im not too worried about pressure on the axles, I would rather have a potential problem, then a problem like i have now with the rubbing.
  9. BUDDY
    BUDDY 1/2 ton status
    Apr 28, 2000
    744
    Midland, TX
    Just adjust the steering stops so that the tire don't turn that full distance.
    Look at this picture -
    Do you see the shiny brass bolt right in the middle? There should be something similar to that on you're D44. Adjust the one on the passenger side knuckle out a little at a time until when you turn you're wheels lock to lock, you don't hit the pitman arm.
    The stops on a D44 or 10-bolt are typically on the back of the knuckle, so look all over it to find it.
    Fixed.
    This will also prolong you're knuckle u-joint life as well, but it does decrease you're turning radius.
    HTH,
    Buddy
  10. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Ok I have a question about the pic above. What is this on? I see you have what appears to be total hi-steer but you have a tie rod still in the factory location. The TRE on teh arm can;t come from the passenger side cuz that ain't typically where the gearbox is (Steve Watsons is the exception) What gives? I'm guessin you have full hydro on that axle to get that kinda breakage?
  11. BUDDY
    Apr 28, 2000
    744
    Midland, TX
    I would imagine that the person who owns this has hydro as well, but that & the breakage, (which is quite impressive I must say), is immaterial to his question. I don't know who's truck this is, but I do know that it's a D60 front, with a high steer tie-rod, (& the stock tie-rod :confused: ), that I pulled from the gallery here as a reference. Maybe i should've picked a different picture as this one is distracting from the issue at hand.
    I was merely pointing out the steering stop, (shiny brass bolt) to try & help sta500666 remedy his rubbing issue.
    Later,
    Buddy
