Tire Siping
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JoeAngelicchio, Mar 28, 2000.
  1. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    Has anyone siped their tires? With a siping tool or utility knife? Or at a shop? What benefits have you experienced?
    <font color=green>Joe Angelicchio</font color=green>
  2. MICHIGAN BLAZER
    MICHIGAN BLAZER 1/2 ton status
    296
    Middleville Michigan
    a few years ago i had a 85 Grand Wagoneer and i needed two new rear tires for it so i bought 2 bfg all terrains and had them siped....Wow that thing really slinged the mud.....not sure if it was just because i had become accustom to thin treaded tires or what. siping really opens the tread up....quiets road noise down a lot too. I would consider siping again. oh yeah, the tire shop did it for me
    <font color=red>MICHIGAN BLAZER
    <font color=green>89 Fullsize Blazer
    87 Cherokee
    65 IH Scout
  3. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    I tried sipping once...did not last too long...it was hot and I was thirsty.... [​IMG]
    <font color=green>Eagle86K5[​IMG]
    <font color=red>Only guy I know that can get out of line in a one car funeral
  4. JoeAngelicchio
    Feb 18, 2000
    628
    hehehehehehe
  5. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    I know long haul trucks do it . I've heard longer tire life , better traction on ice and longer life of the tire.
  6. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    my 38" Swampers are siped by a machine at America's Tires. Swampers are alittle loud with road noise and it cut down clost to 60 % of the singing. They also run cooler and last longer. the tread on these are barely worn and I was driving this beast as a daily driver 100 miles a day round trip on the freeway. My 36" Swampers didnt even last half as long and they were not siped. They also do a great job in the rain.
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    BK is right on, the siping make the wet weather traction (specifically braking) much better. Lots of the tire stores in the Portland area offer this service. And when you are a webfoot (Oregonian), you know ALL about rain...........much like Zonies know about Dry Heat! LOL [​IMG]
    '79 - 406 w/IROC TPI - K5#5 - a <font color=orange>sickness[​IMG] <font color=blue>you never get enough of!! [​IMG]
  8. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    ok, i figure that siping is the proccess of removal by cutting of the tread.
    is this done in a certain pattern? are you just making the contact part smaller, and the grooves bigger?
    can i sipe my mom's 13" whitewalls, and throw 'em on the beast and rip up rubicon?
    should i do this where it can't be noticed (sipe unseen?)
    <font color=purple>delta9blazer</font color=purple>
  9. windrider
    windrider Registered Member
    Mar 3, 2000
    52
    Wisconsin
    I had tires siped but they were used for ice racing cars. It worked good.
  10. DangerB
    DangerB 1/2 ton status
    420
    Frisco, TX.
    I thought siping sounded like a scam when I heard about it. Allthough these are some good testimonials. Are we sure? Any negative comments?
    DangerBrett[​IMG]
    <font color=blue>harder, faster, longer, stronger</font color=blue>
  11. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    DangerB
    The only negstives I have heard about siping are that the treads may have a tendancy to chunk away easier (smaller tread blocks rip off easier)and in alot of cases, it may void the warranty unless you get the shop who sold the tires to you sipe them and agree to warrant them anyway.
    Other than that, ice and wet weather driving in addition to tread life are supposed to be greatly improved like the others have said.
    Brian
    Still in search of the TBI KING!!
  12. BlueKnight
    Mar 6, 2000
    1,518
    Oregon
    Actually I watched them do it. They took a saw and cut slits on all the knarls and tread surfaces laterally across the tread. It isnt hard at all, but you can over sipe to and destroy your tire.
  13. Steve88
    Steve88 1/2 ton status
    526
    Sunny Arizona !
  14. colorado_emt
    colorado_emt Registered Member
    Mar 12, 2000
    84
    Arvada,CO
    I've got 33x12.5's and thier siped i've gotten it on all my tires since i found about about it. Makes tires run cooler and more quiet. I like it. Improves traction on wet roads alot. About chunkes riping out, a few chucks have riped out but only about 10 in total for all of my tires. very small chucks. However i wouldn't recommed if you do alot serious 4 wheelin'. I could see in this case loseing alot of chunks. But other than that go for it!!
    Chris
    '79 K5
  15. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    When correctly done, siping only makes a thin cut in the tread. Little to no actual tread material should be removed. As it was explained to me by a BFGoodrich Aerospace tire engineer, the sipes increase the tread's ability to flex and conform to surfaces, therefore creating more traction (most situations), better handling, and less heat buildup in the tire carcass. This is much different than grooving, which physically removes portions of rubber to modify or re-create a tread pattern. Grooving immediately makes the tire illegal for the street. But, how many cops will know your tires aren't what they used to be??
    That's my 2 cents...
    With all these pennies I'm throwing around, I could probably buy that new motor!!
    [​IMG] Semper Maintenance!
    [​IMG] So many ideas, so little money...
  16. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    You can elimanate most of the chumking by simply sipping the center tread area, avoid doing the outer lugs. Its really kinda neat, makes one wonder why the Manf. don't do it automatically to all their tires..HMMMMMMMMM lasts longer, works better...means less tires purchased...yeah thats the reason...WK
  17. Mr Red
    Mr Red 1/2 ton status
    263
    Washington, DC Metro Area
    Right on White Kight!!! Kind of reminds me of those 150 MPG carbeurators that never seem to appear thanks to the oil companies (alledgedly)[​IMG]
    <font color=red>David, '86 K5</font color=red>
  18. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    White Knight is right about the siping. When rock crawlin with tires like swampers the center lugs are too big to flex around rocky surfaces. Siping alows those big center lugs to conform to the rocks. My 36" Swampers are siped in the middle and I wouldn't have it any other way. Siping the outside lugs will make the tread tear off though.
    David 75K5
    [​IMG]http://www.renschler.org/~goldrush
  19. delta9blazer
    1,646
    OK, so i can take a razor blade, slice the middle third of my tread lugs laterally across the face?
    (the lugs in the middle of the tire, not the middle third of every lug)
    badda-bing, badda-boom; increased traction, mileage, and longevity?
    or is there a bit more science to it?
    how deep? to the wear indicator?
    yet another reason CK5 kix so much ass.
  20. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    AND if this is done I would assume that most of the warrinties would now be void??!!
    Unless you have a hazard warrinty and you punch a hole in the sidewall then it should still be coverd.?
    Rock ON![​IMG] 72 K5 [​IMG]
