Tire size (again)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mint90, Jul 9, 2000.
  1. Mint90
    Mint90 Registered Member
    Jul 9, 2000
    33
    Illinois
    I read, look, read, look. Somebody's full of it. I have a '90 K5, all stock. It came with 31s. Some say only 32s will fit, some say 33s will fit....which is it ???? The specific tire I'm considering is BFG MTs...either 32x11.5 or 33x12.5 the 31s seem to have LOTS of room, but I read conflicting accounts as to which will fit without sheet metal modifications ... either by man or by tire. Stock aluminum rims will remain. Help is much appreciated.
    Mint '90 K5, All Stock, All Options, 49K
  2. 82Jimmy
    82Jimmy 1/2 ton status
    Jun 9, 2000
    702
    Personally 31's are the largest i can get in mine...somebody says my 82jimmy is on drugs, but it rubs. A friend of mine has some 33's with a 2in body lift and fender trimming and they rub all the time...its only a 1in difference so i wouldn't really worry about it...
    <font color=blue>If its too loud, your too old.</font color=blue>
    <font color=red>Cameron</font color=red> <font color=green>Burnett</font color=green>
  3. CruisinK5
    CruisinK5 1/2 ton status
    Jul 8, 2000
    164
    Georgia
    I have 32"s on my '80 Blazer and they rub when I turn onto a steep incline. So I would go with 31"s but you could get away with 32"s. I would say 33"s are out of the question unless you are going to lift it a little.
    "Have you driven over a ford lately?"
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    My K5 had 32" tires on it for years and I don't see any signs of rubbing.
  5. hpfire7227
    hpfire7227 Registered Member
    Mar 14, 2000
    75
    Holland Patent, NY
    I have a stock 89 with 32X11.50X15 BFG All-Terrains and stock aluminum rims, and beleive me, there's definately room for 33's. Actually, the only thing that kept me from getting 33's is that I have 2.73 gears. I guess it depends on the rig and the tire make itself. But if yours is a 90 and you're looking at BFG's, go with the 33's and I'm sure you'll be fine. Good luck.
    10 BOLTS O' FUN
  6. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    Ok,I have 33x12.50 BFG ATs on my '84. I have 2 inches of lift and no trimming. It does fine for normal driving and mild trails. But when I get a little more agressive on a trail, and I make my suspension flex alot, the tires rub.
    You have to remember though that each rig is going to vary a little as far as suspension travel is concerned. This will depend on several things: age, wear, type of lift, manufacturer of lift, individual driving styles, and the driving history of the rig its self.
  7. 4x4blazer
    Jun 14, 2000
    278
    Louisiana
    2.73 gears ?
  8. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    The reason why people have differing accounts of what hits and what fits could be:
    1) All tires are different acutal heights (yes they differ greatly from the stamped size)
    2) Rim width makes a big difference in what works...an 8" rim tucks the tire under the fender alot better than a 10" rim
    3) Depends on what kind of wheeling you do, if it doesn't hit on the street but does when you get really twisted up in the rocks...and some folks don't even take their trucks off road (we pray for them every chance we get)
    4) What shape your suspension is it, if it sags, if your air shocks boost the truck, whatever
    5) If you're willing to modify sheetmetal to get your tire in there.
    And there's probably a lot more but I'll bet nobody's full of it, there's just too many variables to work with here.
    [​IMG][​IMG]
    Durant, Ok
    '79 Blazer in progress
  9. laketex
    6,220
    North Texas
    nice looking truck btw!
    [​IMG][​IMG]
    Durant, Ok
  10. Udy
    Udy Registered Member
    Apr 2, 2000
    79
    fairport NY
    I bought my '91 K5 with 33x12.5x15 BFG ATs mounted on the stock 7 inch wide aluminum wheels from the original owner (216K miles-reciepts for at least 4 sets of 'em since new). He replaced the stock 31 inch Lerados ASAP. the only rubbing was on the driver side due to width. The tire would rubb slightly on the steering arm socket at full turn (no problems though!). Check out "Brian Udovich's '91" in the picture section for a glimps the combination (no lift and 33s before I added 35s and a six inch lift.
  11. hpfire7227
    Mar 14, 2000
    75
    Holland Patent, NY
    Yes, 2.73 gears. (sob sob)
    10 BOLTS O' FUN
  12. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    If your still gonna run your factory wheels (15x7) then I wouldn't go for the 33x12.50, whether they rub or not. Those tires would be so bowed in the middle you'd wear them down in a heartbeat. I ran 33x12.50 on a 8" rim one time and that was bad enough, on a 7" would be asking for trouble.
    89 K5 Silverado
  13. MICHIGAN BLAZER
    MICHIGAN BLAZER 1/2 ton status
    296
    Middleville Michigan
    laketex hit everything. There is no definate answer with out physically putting the tire on your blazer. Everybody's rig is different. Probably the newest blazer on this forum is what...9 1/2 years old!! Assuming you didn't put brand new oem springs on it...it's gonna sag a little, and how much sag depends on what your blazer was used for in the past...towing, no towing, having heavy weights for owners, having heavy weight owners w/a couple of heavy weights for kids...it all depends. I'd suggest figuring out what brand & kind of tire you want...so the only left to figure out is the size...narrow it down to two sizes. Most decent tire shops will mount a tire for you on your truck if your not sure if it's gonna fit....mine did. The shop guys didn't think a 35" would fit, but they said they'd mount it for me to find out for sure....it fit. good luck.
    <font color=red>MICHIGAN BLAZER
    <font color=green>89 Fullsize Blazer
    87 Cherokee
    65 IH Scout
  14. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Just to add to it about all rigs are diff., i have 33" 12.50 on 10x15 rims and 4" suspension w/3"body and I can get the tires to hit when twistin it up on the trail!
    Of coarse now the corners of my rear frontfenderwell are pushed in from the tires rubbing and me finnishing the job with a 4lb sledgehamer.[​IMG]
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  15. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Hey Burt, funny you mentioned that b/c my 10x15 35" tires rubbed my fenders too, when I was wheelin and got all twisted up. I got 4" susp and 3" body too. Wierd.
    But yeah, like the others said, depends on your rig. But just by looking at your pic, I would 32" max. And that is one sweet looking rig. Too clean I think, but very nice looking.
    Boss
  16. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I am pretty sure 33s will fit w/o a lift but only use it like that on the street. The guy I bought mine from put 33s on in August of 98 and the reciept said to test fit the tires and they must have fit because they were on there for a while before the lift was put on-I think Dec 98. the rims are 15x10. BTW thats a pretty cool truck.
  17. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    When I bought my 85 last month the guy threw in a set of 33's on 15X10 rims. The suspension is bone stock and the tires fit just fine. It rubs on full turns and it tore off my chorme trimming while doing some minor wheelin'. So its fine to run 33's on a stock suspension but just keep it on the street!! I'll be gettin lifted this weekend =P
    BLAZE IT UP!!!
  18. Mint90
    Jul 9, 2000
    33
    Illinois
    Thank You all for your help, as well as the compliments ! Both are much appreciated !
  19. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    try this....see if you have a friend or neighbor,(the cute girl up the street for instance), ask to borrow the tires for a short trip around the block (any size you prefer) and see if they rub on your ride....its the only way to be sure. I personally have 33s with a 15 by 10 inch rim on mine, I did trim with the wiz wheel some. JS
  20. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    I have a 90k5. What size is the stock rim?
    [​IMG]Go prepared
    I have a Shotgun a Rifle and a 4WD(K5) and Country Boy Can Survive!!!!
