tire size/axle ratio RPM calculator needed,
Discussion in 'The Garage' started by R72K5, Aug 8, 2005.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    with 31" tall tires and 4.57 axle and 1:1 ratio final gear in a manual trans what would cruising engine RPM be at 55 and at 65 ?
    trying to see if am gonna need taller tires to keep RPM down to where the truc can be driven long ways on freeway continuously without hurting old 350 engine
    what do you thnk is safe RPM to stay under for extended periods
    thanks
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    looks like 3221 RPM is what it would be running at 65mph
    would that be bad for extended periods of time with an old high mileage 70's 350 ?
    thanks
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Yeah, that's a bit much in my opinion.
    I'm going to see if I can post this table directly. If I can, it's for a 1:1 ratio. Higher RPM's for autos, and lower for auto's w/ OD.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep it shows thanks im saving that one :D
    also manual trans be lower RPM too,- than autos anyways(of identical range ratio)
    thanks :thumb:
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    This is the best RPM calculator I have found and it is pretty darn accurate also.
    RPM Calculator
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    thanks :D
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    2700 and 3200 rpm, 55 and 65mpg with the 4.57 and the 31" tires
    looks like i need to dump the 4.57 junk and find a 4.10 third member for this eaton axle
    or just 14 FF it, 3.73 or 4.10
    i cant be running those RPM's with an old 350 like this, it wont last
    thanks :D
  9. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    It, and others can be found here at:
    4lo.com
    They are on the left side in the menu.
  10. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
