Tire size conversion
Discussion in 'The Garage' started by sickquad, Nov 12, 2004.
  1. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Anyone have a tire size conversion from the LT sizes. I know there is a chart floating around somewhere, haven't found it yet though.
    Also, what is a LT tire versus a tire which just gives inch dimensions for there size. Is it just a different designation of size?
    -Chris
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    285-80r16
    285 is section width in milimeters
    80 is the aspect ratio, side wall hieght in relation to section width
    r is radial
    16 is rim diameter
    285mm x 80% x 2 + 16" = tire hieght of 33.95"
    is that what you were asking?
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
  4. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    -Chris
    Think you're confusing LT for P-metric.
    An LT tire is a "light truck" tire as opposed to a P-series "passenger car" tire. Usually means stronger tire, higher capacity, and/or more aggressive tread.
    P-metric or metric tire sizes are just stupid. First numebr is tread width in mm, next is a ratio of sidewall to tread, and last is the wheel diameter in inches.
    A 265/75-16 is therefore 265mm wide (~10.5") by 31.6" (2 x .75 x 265mm + 16 = ~31.6") in diameter on a 16" wheel. More or less a 32x10.50x16 in the olden days.
    Anyway, you can get stupid size tires that are P and stupid size tires that are LT, so the LT designation isn't just to do with size, as it also implies type.
    HTH.
    -- A
