Tire size question. *DELETED*
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 1bigchev, Mar 25, 2003.
  1. 1bigchev
    1bigchev Registered Member
    Jan 27, 2003
    8
    utah
    Post deleted by 1bigchev
  2. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Re: Tire size question.
    You want 38.5s and have 10" of lift........... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/eek.gif
    Greg72 has I think 8 total inches of lift with 38.5s and I will hopfully have 39.5s or bigger with 6". Of course Greg didn't "need" to cut and I will. /forums/images/graemlins/thumb.gif
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    The'll fit , no sweat. I have 42's and awhile ago it was only 11", 38's will fit fine.
  4. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Kameron,
    8" for 38's will be fine. I can think of at least 2 members here who run that setup with NO cutting and it works fine.
    That much lift will be stiff enough to prevent flexing, and will keep the tires off the fenders. /forums/images/graemlins/smile.gif
  5. 1bigchev
    Jan 27, 2003
    8
    utah
    Greg I have 1 more question for you... you said that the springs will be stiff enough to keep me from flexing and keep the tires off the wheel wells. The only problem is that with the current set-up I have I have been in spots where the 35"s that I currently have rubbed. if the 35"s rub wont the three extra inches on the 38"s potentiate easier rubbing? If so what canI do besides stop playing so rough?
    Kameron
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I am guessing that they rubbed at the front of the rear wheels and and maybe on the "Fang" at the front of the front fender. That is where my bald 33's rubbed with a 4" lift.
    If you look at the rear wheels you will notice that they are not centered in the wheel wells. If you move the rear axle back you will lessen the chance of them rubbing.
    For the front most people just cut the "Fang" off.
  7. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    FYI - going from 35s to 38s only gives you 1.5" in radius.
  8. cleszkie
    cleszkie 1/2 ton status
    Apr 23, 2001
    121
    Santa Ana, CA, USA
    It also make a difference what width rim you are running, and the backspacing. A very wide rim will have interference problems with full wheel stuff in the rear and full steering lock up front where a narrower rim might not with the same tire diameter. I run 35" tires on 16.5x6 rims with a 6" lift and do not even get near the sheetmetal in full flex and steering lock. If I went to say a 10" wide rim, I'm sure that I would get some rubbage. Just my $.02.
