  1. BigGray89Blazer
    BigGray89Blazer Registered Member
    Sep 27, 2000
    6
    Can anyone tell me what the largest size tire I can put on my Fullsize 89 Blazer without installing a lift?
  2. baldbandit
    baldbandit 1/2 ton status
    Jun 16, 2000
    282
    Marshall TX
    44" boggers if you cut enough sheetmetal out!LOL!![​IMG] Sorry, i couldn't help it! All jokes aside, it just dependes on what you are going to do with the rig. Rockcrawl? muddin?show-n-go? and if you want to get the sawzall out and cut the fenders to fit what ever tires you want to run. To answer your question (assuming that you don't want to cut alot of the fenders out), you can fit 31x10.5 without trimming and 32x11.5 with minor trimming! Hope that helps!
    baldbandit
  3. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    As long as the suspension is stock and you dont flex it too much, you can easily fit 33s if they arent a tire with side lugs. My truck is stock and I bought it with 33" Thornbirds and I never got them to rub except with the wheel cranked ( side lugs hit steering arm ). I also have Warn fender flares and my tires never touch them. My current tires are A/Ts and they do not rub at all. I hope this helps.
    PS, my truck is an 82 if that makes a difference.
