tire size?
Discussion in 'The Garage' started by k5enigma, Jan 19, 2006.
  1. k5enigma
    k5enigma Newbie
    Jan 19, 2006
    virginia
    ok,finish 3 inch body lift,wont be till summer doing an 6 or 8 in suspension lift but for now does anyone know if 35 s will fit and ride ok?
    thanks
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Are you asking if 35"s will fit with only a 3" bodylift?
    Yes
    I would highly disagree with doing a 3" BL and a 6" suspension lift on the same truck.
  3. k5enigma
    k5enigma Newbie
    Jan 19, 2006
    virginia
    so, why would you disagree?with 3 in body and 6 in lift?
  4. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Personally I stay away from any and all body lifts. Seen enough bad things happen to try. I know many people run 'em with no probs, but I never will. I have run 35's with 4" lifts on 3 different rigs. With just a 3" body lift you probly will still get some rubbing when out wheeling. People here are running 40"+ with 8" of lift and no body lifts. Some run 40's with 6" and a zero-rate.
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i agree, i dont like body lifts. i guess they work fine, but the idea of all that space between the body and the frame, i just dont like it. at most, i would consider a 1" from ORD, but thats it.
    i had 35's on 15x10 rims with 2" lift before, only rubbed on sharp turns
  6. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    I'm gonna do the 1" ORD on mine, mainly because I gotta replace all that stuff anyways. An extra inch never hurts with 4" suspension and 36's.
