tire size
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by showmeburb86, Oct 21, 2006.
  1. showmeburb86
    showmeburb86 Registered Member
    Oct 7, 2006
    17
    Kansas City, MO
    What is the max size you can put on a stock burb with no lift?
  2. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    3/4 or 1/2 ton?
    There is a big diff.
    I have seen 3/4's with 35" stock and 1/2's with 33" stock
  3. dyeager535
    26,979
    Stock wheel size I assume?
    33x10.5R15's are about the largest that no one has had a problem rubbing.
    Increase the width, and typically they hit when cornering.
    Innumerable threads on this subject BTW.
  4. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    had 33 12.50 on 15x10s on my 86 half ton with no rubbage... you can hack the fenders to hell and back and run 37s...
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ive seen 35x10.50s on what looked like a stock k10
  6. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    how about 35X12.50 on a stock k-5?
    a little fender trimming in the front, the fronts would rub on the inner wheelwells at full steer while flexing. The rears would tuck up nicely:D
  7. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i wasnt thinkin bout your rig. but you prove that 35x12.50's can fit:bow:
  8. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Depends on your definition of "fit."
    To really screw you up what brand should be designated as well. The actual size of a tire varies between manufacturers.:doah:
