tire size?
Discussion in 'The Garage' started by 88GLAZER, Jan 21, 2003.
  1. 88GLAZER
    88GLAZER 1/2 ton status
    Nov 19, 2002
    111
    West Virginia
    I am going to be running a 6" lift, and I wanted to know how wide of a tire I can run without trimming the fenders. being from nj our redneck rigs tire's cannont stick outside of the well. So how wide can I go with tires using flares
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I would stick with a 12.5" width. That will fit well without needing trimming. And, combined with a wheel with 4" backspacing...should keep it tucked under the front pretty well (that's what I have) - back is no worry because of the narrower axle. Any wider of a tire/less backspacing - and the front tires might start attracting the cops. Mind you this is with stock fenders - no flares.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    If you want to go wider tires, can't you use fender flairs like Bushwackers.
  4. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    he can but that is just more money to spend. i'd say go with bfg mud km's. good tires and not that expensive. they come in a 35x12.50. it would be good to use. later.
    jacob
