tire size
Discussion in 'The Garage' started by 82_k5, Oct 19, 2003.
  1. 82_k5
    82_k5 Registered Member
    Oct 3, 2003
    94
    I need to know....... I have a 1982 stock fullsize jimmy, would 32's fit with out any trimming? thank you /forums/images/graemlins/ears.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I have 33s that measure about 31-32x12.50. They worked fine with no rubbing until I replaced the fender and this fender won't align right. It rubbed when the passenger side stuffed. Fender trimmed now.
  3. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    from what ive heard every truck is different..go gettem and find out..if they rub..and you dont have money for a lift or something..put some zero rates on all 4 corners or some addaleafes
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    If you are using stock GM rims, they should fit. I have had 2 stock blazers with 32's. I put a set of after market rims, 15x8's on 1, and then the tires hit, but just had to trim the inner lower lip on my front fenders to make them clear agian. Nothing you could even see. but each truck is a little different.
