tire sizes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Alexmart1, May 31, 2001.
  1. Alexmart1
    Alexmart1 Registered Member
    May 18, 2001
    36
    well i need tire pretty dam bad, what are the biggest meat i can put on a stock 79 4x4 blazer, thank n advance
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    the answers to this will vary i have 33x12.5x16in tires and no lift and no rubbing BUT i have no backspacing on my rim's and that is why i can get away with it. if you have a negative backspacing you will rub when articulating so the key is no backspacing or + backspacing hope this helps
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>
  3. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    All trucks are different, so there is not one right answer for all K5's. A 31x10.50 will for sure fit, 32's usually fit and 33's sometimes fit and sometimes don't. The other guy said his 33's fit fine with no lift, but I lifted the front of my truck 2.75 inches and my 33's still rubbed a little bit so I had to trim the fenders. Just something to keep in mind.
    '73 K5
    Chevy good...Ford bad
  4. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    32x11.50-15 for 8 inch wide rims.
