tire wear
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NYC K5, Apr 4, 2000.
  1. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    my front tires wear extreemly rapidly on the outboard of the front tires, but they are like brand new on the inboard side. im running 31*10.5 bfg at. im was told to adjust the camber(wheel tilt) but how do you do it with full axles? is this just a blazer thing?
  2. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    I'd check the toe-in first, i had the same problem a couple years ago, got it aligned, the guy said the toe was way off, now they wear alot better.
    RaisedK5
    "Friends don't let friends drive Fords"
  3. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    I have a problem with all four of my tires. There's chunks of side wall missing. Big hunks of the tread haved been ripped out. The sidewalls are gouged and cut up. The balance weights have been ripped off and the wheels have been dented and ground away. Is this an alignment problem? Oh yea I did that. Seriously though I would take a good look at your tie rod, more then likely it has a bend in it and that changes your tire alignment. Staighten it or better yet replace it.
    CB
  4. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    ......and use the brake pedal before turning.
    lol
    the Goose
  5. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    check your tie rods and linkage. look at your suspension components like the ball joints upper and lower control arms and bushings to.
  6. NYC K5
    Apr 3, 2000
    185
    but then id wear my brakes! lol
    people who say size doesnt matter, have small things, and im not compensating.
