tire wear
Discussion in 'The Garage' started by twistedminds, Dec 15, 2003.
  1. twistedminds
    twistedminds Registered Member
    Dec 11, 2003
    10
    I have a straight axle in the front of my k5. My tires in the front are wearing like i had IFS and my alignment was off. The outside of the tire, is worn to the legal limit and the inside is still pretty good. How is this possible?
    -ken-
  2. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Has fixing your alignment not helped?
    I would start with checking your ball joints. Then move to wheel bearings. I would think that you would have some decreased steering performance with these problems though.
    Caster/camber problem maybe?
    -Andrew /forums/images/graemlins/usaflag.gif
  3. twistedminds
    Dec 11, 2003
    10
    i havent gotten an alignment, i have crazy steering problems. im gonna get an alignment when i get my new tires. im ordering them tomorrow, when they come im gonna have a local place put them on and do an alignment.
  4. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    sounds to me like hes got some crazy positive camber
  5. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    quit making fast corners
  6. Ryan B.
    Jul 18, 2001
    5,693
    CA
    That would be too much toe in, if just the outside of the front tires are wearing...
    If you think about it if the tires are pointed like this /---\ They are gonna wear a lot more on the outside... you need to adjust it so it has more toe out instead of toe in...
    if you toe it OUT too far then they will be pointed like this \---/ and they will wear on the inside of the front tires.
    You actually want a little toe in because as your going down the road the tires will want to tend to get pushed out so they will be pretty much straight.
    /forums/images/graemlins/thumb.gif
  7. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    my buddy who owns an alingment shop told me that for straight axle like ours with big tires (33+) wear better with zero toe in. can't remember the reasons why but hes been doing this for 20+ years so i trust him.thats how mine are set up and are wearing great. my $.02
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I have this problem too. My toe is fine, I was told something about offset balljoints. I think one way to cure this is to just get a king pin 60, sooner or later.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I don't think that they make offset balljoints for our trucks, but either way, the concept of changing the camber to achieve a proper alignment is the same.
  10. clubba68
    Dec 6, 2002
    1,511
    Tim,
    Have you said what that thing is in your Avitar is? Why it changes colors? And why the hell is it running backwards? /forums/images/graemlins/thinking.gif /forums/images/graemlins/grin.gif
  11. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Too much toe would 'feather' the tread not wear the outside only.
    I thought they made thin shims for behind the spindle to correct camber?
    Rene
  12. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yes, I thought they made shims too, but I was told no. However I had heard of them here, so maybe someone has used them before.
  13. Masher
    Masher 1/2 ton status
    Mar 7, 2002
    123
    SW Michigan
    I have seen the shims at complete off road. They have lots of good dana parts too. Just add a .com to their name.
  14. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    my truck has camber shims in the spindle too. they do exist.
  15. twistedminds
    Dec 11, 2003
    10
    thnx for all the insight guys.
