Tire & Wheel size ? for stock height
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stickseler, Oct 29, 2002.
  1. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    Northern Virginia
    OK I've searched for the answer and now I'm more confused. /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
    I'm gona hold off on the lift kit for a while but I need to get new tires. Will Pro Comp M/T's fit?? The size I'm looking at with wheels is
    33/12.50R15 M/T 15x10 A/E0589 w/3.62" backspacing
    33/12.50R15 M/T 15x8" A/E0589 w/3.25" backspacing
    Which will fit best on a stock 89 K-5?? I plan on zero rates and 1" body lift soon but probably after christmas.
  2. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    With the 15x8 inch rims you might be able to drive it on the street without rubbing, with the 15x10 inch rims I think you would have rubbing even on the street when turning. This of course depends on much much your front springs have sagged with time. I put 15x10s with 33/1250s on mine without lifting it and I had to cut both the front and the rear of the front fender to keep it from rubbing. If you don't mind cutting your fenders a little go for the 10x15s.
