tire wobble....BAD
Discussion in 'The Garage' started by shaun89, Jan 27, 2006.
  1. shaun89
    shaun89 1/2 ton status
    Aug 7, 2005
    1,942
    center of CT..ish
    i got some 38" gumbos(I didnt buy them), one tire in the front at about 30-35mph it thrashes back and forth like its about to pop off the truck, and the truck goes crazy, so i switched it from the driver side to the passenger side, it stopped for a day or so then started again with the same tire...it doesnt always do it, just sometimes...mostly when slowing down....any clue what it could be?:doah: im gonna stab it soon.:mad:
  2. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    Could be tread seperation, or an out of round tire. If it is tread seperation, then the tire is dust. But if it is out of round, then it could cost you more money to have it shaved then the tire is worth. You say you did "not buy them". If they where given to you for free, then now you know the reason why. :D
  3. shaun89
    Aug 7, 2005
    1,942
    center of CT..ish
    hmmmm tread separation....that could be painful
  4. 86Cucvbeater
    86Cucvbeater 1/2 ton status
    May 24, 2005
    428
    north carolina
    Maybe check the kingpin springs and bushings if your truck has a dana 60
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Sounds like death wobble to me.
  6. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    no my truck only has a 10b (i got 3/4ton ready to be put in but no 8b rims or tires)...its just not the usual death wobble, its shaking left and right, jerking the steering wheel back and forth...only at 30-35mph...thats what is reeeeallly confusing me, i dont understand y it would do it then and not at any faster or slower speeds.:doah: :mad:
  7. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    try putting it on the back.......see if it does it then, if not then its in your frontend
  8. rustyear
    rustyear Registered Member
    Jan 25, 2006
    19
    ROY, UTAH
    this exact same thing happened to me, it turned out to be tire balance...i had no clue at the time, it was so bad it felt like the wheels were coming clear off the ground. i replaced shocks, checked all bolts a couple of times, replaced the steering stabilizer...then had the tires spin balanced by a guy who knew what he was doing, and presto...smooth as glass. it was at low speed, too, but i dont know if it would have gone away if i went faster cuz at the time, speeding up when my front end was wiggin out that bad was the last thing i was gonna do.
  9. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    Check the draglink, that is the reason my old 10 bolts got death wobble. Death wobble in a 10 bolt is not common, something needs to be checked. Have a friend steer the truck and look for play in tierod's, balljoints, draglink, etc.
  10. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Put the front end on jackstands.....then spin the tire and "sight" across the top of the tread as you spin it slowly. If you see the tread moving up and down as it rotates, then you know you have an egg-shaped tire. No amount of balancing will fix that.
    If it spins true and round, then you need to look for other culprits.
    Good luck.
