tire ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by paul_cfh, May 2, 2000.
  1. paul_cfh
    paul_cfh Registered Member
    Apr 22, 2000
    82
    OH (for school) NH to live
    sorry this isnt a blazer ? but i need some info...........i just pulled the tsl boggers of my truck (to put on my blazer) and switched the super swampers that where on my blazer them...........my ? is what would cause the inside of the tread to wear and only on the back set .........i know i should have rotated them more......thanks in advance.....
    <font color=blue>where the road ends the fun begins</font color=blue>
  2. chaka73
    chaka73 1/2 ton status
    377
    Southern California
    Dont really know but did you check the air pressure? maybe that was it.
    keep blazin !!!
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    If the center of the tread is worn and outer edge isn't, this is a classic case of having the tires over-inflated. If all 4 tires were at the same pressure, the reason you are seeing this on only the back tires is because the rear of most vehicles (especially pickups) are much lighter than the front, and more weight requires more air. I typically run about 5 pounds less air in the rear tires on my Blazer to compensate for this.
  4. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Something else to think about...Gasoline weighs approximately 6.2 pounds at sea level, in a 31 gallon tank that can account for 192.2 extra pounds with a full tank....FYI
    <font color=green>[​IMG]Eagle86K5[​IMG]
  5. paul_cfh
    Apr 22, 2000
    82
    i'll try that with the swampers and see if it helps
  6. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Inside of both rear wheels huh? Sounds to me like your rear axle housing is slightly bent causing the tires to run slightly more on the inside. For your sake I hope it's something else, but I don't know what it would be.
    '73K5,SM465,NP205,33"BFG,4"TuffCountry,3.73:1diffs
    350.4bolt+mods,Warn8000#,Factory skidplates
  7. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    I doubt that either you or any previous owner wraped a chain or strap around the rear end to pull it out of a stuck did you?
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  8. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    A parts truck that I had for a while had a rear 12 bolt that was bent like that. You could look at it close, and it looked like it was smiling. I assumed that the truck had been airborn a few times.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  9. paul_cfh
    Apr 22, 2000
    82
    sorry i took so long to reply didnt check it .........nope never hooked a chain around the axle but it has been air born a few times ........quess i have a good reason to get that 14 bolt after all
