Tired of fixing my truck, might sell
Discussion in 'The Garage' started by anatomiczero, May 3, 2003.
  1. anatomiczero
    anatomiczero 1/2 ton status
    Jun 26, 2001
    418
    Washington
    Current problems:
    >Brakes are worn and the pedal goes all the way to the floor after holding for a min or 2.
    >Ignition cylinder needs to be replaced
    >Headlights went out twice tonight driving on a dark windy road.
    >Shocks need to be replaced
    >Vibration at 40mph
    >fan speed switch broken
    >rust in floornoard over tail pan.
    > 9 mpg
    >The usual rot in fenders and needs paint (current flat black isn't too bad though)
    How much do you think it's worth, or how much do you think I would need to sped on it for it to be reliable?
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Most of the "problem's" could be solved with a little time and some TLC, just tinkering kinda stuff for the most part.
    What the hell, is an Ignition Cylinder? /forums/images/graemlins/rotfl.gif
  3. anatomiczero
    Jun 26, 2001
    418
    Washington
    Umm it's where you put your key to start it /forums/images/graemlins/rolleyes.gif
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    the lock tumble, aka the key lock
  5. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    If its a daily driver, then I could understand. Never being sure of whether you'll make it from point A to B is a hassle. If its not you daily driver, then you should hang in there. A lot of the parts you need are available for cheap at local junkyards, the best being the pull-your-own parts places. Its amazing how many screws, bolts and trim pieces fit in your pockets! Of course I always pay for the big stuff, but still it is alwasy reasonable. /forums/images/graemlins/smirk.gif
  6. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    I'll give you a couple hundred for it, if you deliver it to NC.
    Really, if I had it, I would make it into a trail rig, and buy something more reliable for a daily driver.
