Tired of waiting for FYC for 208...other options?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jekbrown, Aug 15, 2001.
  1. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    As far as my 85 K5 goes I have been sitting on my hands for months now, mainly because I don't want to do any upgrades until I fix my slip-yoke-208-bad-vibes problem. I'd rather not test the durability of the JET T700 I want to get by rattling the heck out of it with the bad vibes. =\ Anyway, the SYC seemed like just the ticket for me, but quite frankly I am tired of waiting for it. Considering this, what other options do I have? What would I have to do to run a 205? If I was going to order a JET T700 tranny anyway, is there any way to get it 205-ready from the factory so I wouldnt need to fiddle with converters etc?? Grrrrr!!!
    Those bad vibes MUST go, hopefully sometime this year. If I can't get something with a fixed yoke...and thus high angle CV drive shafts, I swear my truck is going to rattle itself to death. Helllpppp!!!! =(
    Jason
  2. elkboy
    elkboy 1/2 ton status
    Aug 18, 2000
    293
    Hillsboro Oregon
    How much suspension lift are you dealing with? Is it the tcase, lift or somthing else causing the bad vibration? You may want to checkout highangle drive lines on http://www.pirate4x4.com .
    <font color=red> Elkboy </font color=red> 82 K5 fuel injected H.O.305, TH350/205, 14bolt/10bolt and 39.5 TSL's.
  3. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    You could try axle shims and a t-case drop; might cut the vibes down enough that it's not gonna shake itself to pieces.
    You could also get a CV shaft with a slipyoke, but that's a little expensive, and in my opinion, not a real good fix.
    Best bet: Call or email Jesse at High Angle Driveline and let him know about how interested you are in the SYE, and get a status update from the man who's making the kit. Don't forget to mention CK5 to him...
    It's always darkest just before it goes pitch-black...
    [​IMG] <font color=green>Semper Maintenance!<font color=black>
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Or you could swap to a 241 t-case and do a SYE. Not sure on everything you need to do but you need to change the output shaft on the trans for a 205 swap. I think Stephen at ORD can hook you up with everything you need to convert to a 205.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  5. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Will a 241 swap for a 208 case.... or is there more that needs to be done? Seems like they should or maybe just w/ an adapter... anyone know?
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    208 case has a slip yoke anyway.
    If you really want to solve the problem, do what I'm doing, swap in a 4 speed/NP 205.
    Tim
  7. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Far as I can tell; should be a direct bolt-in Capt! Haven't seen anything to the contrary. You'll also have the better of the two cases if you do so!
    Brian
    89KBlazer
    Build it Right or Don't build it at all!!
  8. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    Well first off I really like the 700R4 overdrive and steep first gear... even though they do have some issues. Also considering I'm a 24 yr old w/ about 65 yr old knees. My left need has had 3 rebuilds and now has both the MCL and ACL replaced w/ liagments from my back so I don't like sticks too much... although I can do it ok, I would really hate to be in a bad spot off roadwise and have something happen or even just the annouance of my knee being too sore, which happens alot. Last off I probably don't wheel hard enough to justify the big heavy 205 in there, but the 4 speed swap would otherwise be a sweet swap.
    -Mikey
