TireLocs anyone running them??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by burbBoy, Apr 9, 2002.
  1. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    I was looking around online at beadlocks and saw these. They sound like they would work well and are a good alternitive to a bead lock. Anyone out there have them or seen them in person??
    http://www.tireloc.com/
    Brian
    82 burb 10/14 bolts, 38.5's, sm465/np205
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Looks a little expensive to me when comparing them to actual beadlock wheels. 4 of them in 15x10 wheel size is over $700.
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    but they are street legal and are cheaper for those of us running 16.5's.
    Titanic runs them. he has for years, IIRC. Someday, i hope to be running these, mainly because of the street legal issue.
  4. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Beadlock wheels are legal in Pa. /forums/images/icons/smile.gif
  5. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    there is no writen law in ca that says beadlocks are illegal...
  6. roadhouse66
    roadhouse66 Registered Member
    Dec 6, 2001
    24
    Sanford, MI
    Beadlocks are legal in Michigan. There a few companies making 16.5 beadlocks now, Trailready for one.
  7. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Link no work.
    <br>
    <br>http://www.tireloc.com/
    <br>
    <br>Brian
    <br>82 burb 10/14 bolts, 38.5's, sm465/np205
  8. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    If you want double beadlocks... run 17" wheels.
    If you want inexpensive beadlocks TrailReady makes them for the same price as the Tireloc system costs. Or, since you weld pretty gosh darn good buy a set of cybrfire's kits.
  9. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Cybrfire is probably the direction I will go. I already have the 15 inch tires. And 44s arent cheap, so I will stick with them. /forums/images/graemlins/cool.gif
    How do you know how I weld?
  10. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    Didn't Greg72 have a set and really liked them?
  11. LucasJ03
    LucasJ03 1/2 ton status
    Sep 18, 2002
    289
    Ft. Fun, Colorado
    I have them and they work great. I ran my tsl's at about 4 psi and had no problems at all. Pm me if you have any more ?'s about them.
  12. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    I've had them for 8 years. I like them but they are not perfect. I wish we had a better distributor here in the US-JD'S in New York is your only option. Here's what I have told my local friends to do. Call Sweden direct and order whatever size you need but tell them you don't need the innertubes or the special valve flap. Should get a slight discount. Then call JD's and order there extra heavy duty farm equipment innertube that's much better than TireLoc's. If you make it that far e-mail me and I tell you how to make your own inflate valve out of common parts for about $5 each and they won't get knocked off or beat up rock crawling.
  13. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    [/ QUOTE ]]
    I got the tireloc beadlock system used from aguy here in CA.
    The kevlar piece is perfect, the inner tubes are OK one is bad, and the inflating gadgets are OK but I would be interested in seing how you did yours.
    I Know Greg72 and seen his setup, he loves it and it works great.
    How much do the HD inner tubes cost? Can I get them from an industrial tire place or is it only JD that has them?
    By the way I paid $50 for all four setups. /forums/images/graemlins/thumb.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
  14. titanic
    Mar 27, 2000
    498
    innertubes were about $10 each. I can send pic to an e-mail address
